Yocto S32V Kernel Panic
4,026 次查看
hennadiyyatskov
We are currently building the BSP 15 for the S32V. The Yocto build is successfull and we can boot from the generated image. However during boot, we get a kernel panic, the init script simply fails with an error (-2).
I've attached the latest bootlog, were I tried to start init directly using init=/sbin/init.sysvinit, sadly the result is the same as for init=/sbin/init
标签 (1)
1 回复
3,674 次查看
KushalShahNXP
Hi Hennadiy,
Did you used correct components from the Yocto build? I mean u-boot, dtb file, rootfs, image.
Please use the latest BSP available (now v16.1) and try again.
Kushal
