errors with S32M24xEVB
455件の閲覧回数
Fero36
Junior Contributor I
I have tried example codes for this kit and the S32M24xEVB_BLDC_6Step_Sensorless is the only one working. What am I doing wrong? The hall gives theese errors (missing headers):
....Building file: ../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.h:44:10: fatal error: Adc_Ip_Types.h: No such file or directory
Building file: ../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c
44 | #include "Adc_Ip_Types.h"
compilation terminated.
../generate/src/Aec_Ip_Cfg.c:41:10: fatal error: Aec_Ip_Types.h: No such file or directory
Invoking: Standard S32DS C Compiler
41 | #include "Aec_Ip_Types.h"
make: *** [generate/src/subdir.mk:78: generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
make: *** Waiting for unfinished jobs....
make: *** [generate/src/subdir.mk:78: generate/src/Aec_Ip_Cfg.o] Error 1
../generate/src/Aec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.c:42:10: fatal error: Aec_Ip_Types.h: No such file or directory
Building file: ../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c
42 | #include "Aec_Ip_Types.h"
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
make: *** [generate/src/subdir.mk:79: generate/src/Aec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
In file included from ../generate/src/CDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.c:43:
arm-none-eabi-gcc "@generate/src/Adc_Ip_BOARD_INITPERIPHERALS_PBcfg.args" -MMD -MP -MF"generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.d" -MT"generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o" -o "generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o" "../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c"
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Gdu_Ip_BOARD_INITPERIPHERALS_PBcfg.h:46:10: fatal error: Gdu_Ip_Types.h: No such file or directory
46 | #include "Gdu_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/CDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
In file included from ../generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c:41:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.h:43:10: fatal error: Dpga_Ip_Types.h: No such file or directory
43 | #include "Dpga_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/Dpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
In file included from C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Pwm_Ip_Cfg.h:54,
from ../generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c:41:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.h:45:10: fatal error: Ftm_Pwm_Ip_Types.h: No such file or directory
45 | #include "Ftm_Pwm_Ip_Types.h"
In file included from ../generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c:47:
C:/Users/nitro/workspaceS32DS.3.5_DP_V10/S32M24xEVB_BLDC_6Step_Hall/generate/include/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.h:46:10: fatal error: Ftm_Gpt_Ip_Types.h: No such file or directory
46 | #include "Ftm_Gpt_Ip_Types.h"
make: *** [generate/src/subdir.mk:80: generate/src/Ftm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
make: *** [generate/src/subdir.mk:80: generate/src/Ftm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o] Error 1
"make -j8 all" terminated with exit code 2. Build might be incomplete.
The PMSM_FOC is like incomplete:
-j8 all
Cannot run program "": Launching failed
Error: Program "" not found in PATH
430件の閲覧回数
Robin_Shen
Did you click click on "Update Code" button for generating configuration files by refer to 4.2 Use Configuration Tool?
Did you install SW32K1_S32M24x_RTD_4.4_R21-11_2.0.0_D2308_DS_Updatesite.zip and SW32K1_S32M24x_RTD_R21-11_2.0.0_P04_D2404_DS_updatesite.zip by refer to 2. Get Software of S32M24X Board Setup Guides?
I am able to build the those three projects without error.
C:\NXP\MC_DevKits\S32M24xEVB\sw\S32M24xEVB_BLDC_6Step_Sensorless and S32M24xEVB_BLDC_6Step_Hall and S32M24xEVB_PMSM_FOC_1Sh
Did you download S32 Design Studio - Releases & Updates here?
And don't forget to install NXP GCC for Arm Embedded Processors v10.2 build 1728 by S32DS Extensions and Updates
Robin
- If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
%3CLINGO-SUB%20id%3D%22lingo-sub-2379659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M24xEVB%E3%81%A7%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%AD%E3%83%83%E3%83%88%E3%81%AE%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81S32M24xEVB_BLDC_6Step_Sensorless%E3%81%A0%E3%81%91%E3%81%8C%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E7%A7%81%E3%81%AF%E4%BD%95%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%EF%BC%9F%E3%83%9B%E3%83%BC%E3%83%AB%E3%81%A7%E3%81%AF%E4%BB%A5%E4%B8%8B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%EF%BC%88%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E....%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%9C%E6%88%90%E4%B8%AD%3A%20..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3E%20C%3A%2F%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A44%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Adc_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3E%2044%20%7C%20%23include%20%22Adc_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FAec_Ip_Cfg.c%3A41%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Aec_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3E41%20%7C%20%23include%20%22Aec_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A78%3A%20generate%2Fsrc%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%E6%9C%AA%E5%AE%8C%E4%BA%86%E3%81%AE%E3%82%B8%E3%83%A7%E3%83%96%E3%82%92%E5%BE%85%E6%A9%9F%E4%B8%AD...%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A78%3A%20generate%2Fsrc%2FAec_Ip_Cfg.o%5D%20%E3%82%A8%E3%83%A9%E3%83%BC%201%3CBR%20%2F%3E%20..%2Fgenerate%2Fsrc%2FAec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.c%3A42%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Aec_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E%E3%83%93%E3%83%AB%E3%83%89%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%3A%20..%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3CBR%20%2F%3E%2042%20%7C%20%23include%20%22Aec_Ip_Types.h%22%3CBR%20%2F%3Earm-none-eabi-gcc%20%22%40generate%2Fsrc%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.d%22-MT%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%20%22generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%97%E5%85%83%3A%20%E6%A8%99%E6%BA%96S32DS%20C%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A79%3A%20generate%2Fsrc%2FAec_Ip_Sa_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20arm-none-eabi-gcc%20%22%40generate%2Fsrc%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.d%22-MT%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%20%22generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FCDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.c%3A43%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20arm-none-eabi-gcc%20%22%40generate%2Fsrc%2FAdc_Ip_BOARD_INITPERIPHERALS_PBcfg.args%22-MMD%20-MP%20-MF%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.d%22-MT%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22-o%20%22generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%22%22..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%22%3CBR%20%2F%3EC%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FGdu_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A46%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Gdu_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E46%20%7C%20%23include%20%22Gdu_Ip_Types.h%22%3CBR%20%2F%3E%7C%20%5E~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FCDD_Gdu_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20..%2Fgenerate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A41%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A43%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Dpga_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E43%20%7C%20%23include%20%22Dpga_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FDpga_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20C%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Pwm_Ip_Cfg.h%3A54%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%E3%80%81%3CBR%20%2F%3E%20..%2Fgenerate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A41%20%E3%81%8B%E3%82%89%3A%3CBR%20%2F%3E%20C%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A45%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Ftm_Pwm_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E45%20%7C%20%23include%20%22Ftm_Pwm_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E..%2Fgenerate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.c%3A47%20%E3%81%8B%E3%82%89%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E5%86%85%3A%3CBR%20%2F%3E%20C%3A%2FUsers%2Fnitro%2FworkspaceS32DS.3.5_DP_V10%2FS32M24xEVB_BLDC_6Step_Hall%2Fgenerate%2Finclude%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.h%3A46%3A10%3A%20%E8%87%B4%E5%91%BD%E7%9A%84%E3%81%AA%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Ftm_Gpt_Ip_Types.h%3A%E3%81%9D%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%80%81%E5%8F%88%E3%81%AF%E3%83%87%E3%82%A3%E3%83%AC%E3%82%AF%E3%83%88%E3%83%AA%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3CBR%20%2F%3E46%20%7C%20%23include%20%22Ftm_Gpt_Ip_Types.h%22%3CBR%20%2F%3E%20%7C%20%5E~~~~~~~~~~~~~~~~~~~%3CBR%20%2F%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%8C%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3Emake%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FFtm_Pwm_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20make%3A%20***%20%5Bgenerate%2Fsrc%2Fsubdir.mk%3A80%3A%20generate%2Fsrc%2FFtm_Gpt_Ip_BOARD_INITPERIPHERALS_PBcfg.o%5D%E3%82%A8%E3%83%A9%E3%83%BC1%3CBR%20%2F%3E%20%E3%80%8Cmake%20-j8%20all%E3%80%8D%E3%81%8C%E7%B5%82%E4%BA%86%E3%82%B3%E3%83%BC%E3%83%892%E3%81%A7%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EPMSM_FOC%E3%81%AF%E4%B8%8D%E5%AE%8C%E5%85%A8%E3%81%AA%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E-j8%20%E3%81%99%E3%81%B9%E3%81%A6%3CBR%20%2F%3E%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%80%8C%E3%80%8D%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%3A%20%E8%B5%B7%E5%8B%95%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%20%22%22%20%E3%81%8C%20PATH%20%E3%81%AB%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20errors%20with%20S32M24xEVB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379769%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%8F%E3%82%A4%3C%2FP%3E%0A%3CDIV%3E%0A%3CDIV%3E%E8%A8%AD%E5%AE%9A%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%8C%3CSTRONG%3E%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E6%9B%B4%E6%96%B0%3C%2FSTRONG%3E%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fs32m24x-board-setup-guides%3AGS-S32M24XEVB%3Fsection%3Dbuild-run_build-run-2%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E4.2%20%E8%A8%AD%E5%AE%9A%E3%83%84%E3%83%BC%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%3C%2FA%3E%EF%BC%9F%3C%2FDIV%3E%0ASW32K1_S32M24x_RTD_4.4_R21-11_2.0.0_D2308_DS_Updatesite.zip%20%E3%81%A8%20SW32K1_S32M24x_RTD_R21-11_2.0.0_P04_D2404_DS_updatesite.zip%20%E3%81%AF%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fs32m24x-board-setup-guides%3AGS-S32M24XEVB%3Fsection%3Dget-software%22%20shape%3D%22rect%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3E2.%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E5%85%A5%E6%89%8B%E3%81%99%E3%82%8B%3C%2FA%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%E3%81%AE%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32M24X%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%82%BB%E3%83%83%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%AC%E3%82%A4%E3%83%89%3C%2FSTRONG%3E%EF%BC%9F%3C%2FDIV%3E%0A%3CDIV%3E%E7%A7%81%E3%81%AF%E3%81%9D%E3%82%8C%E3%82%893%E3%81%A4%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AA%E3%81%8F%E6%A7%8B%E7%AF%89%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3CBR%20clear%3D%22none%22%20%2F%3EC%3A%5CNXP%5CMC_DevKits%5CS32M24xEVB%5Csw%5C%20%3CSTRONG%3ES32M24xEVB_BLDC_6Step_Sensorless%3C%2FSTRONG%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSTRONG%3ES32M24xEVB_BLDC_6Step_Hall%3C%2FSTRONG%3E%E3%81%8A%E3%82%88%E3%81%B3%3CSTRONG%3ES32M24xEVB_PMSM_FOC_1Sh%3C%2FSTRONG%3E%3C%2FDIV%3E%0A%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32-Design-Studio-Knowledge-Base%2FS32-Design-Studio-Releases-amp-Updates%2Fta-p%2F1119315%22%20target%3D%22_self%22%3ES32%20Design%20Studio%20-%20Releases%20%26amp%3B%20Updates%3C%2FA%3E%E3%81%AF%E3%81%93%E3%81%93%E3%81%8B%E3%82%89%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9F%E3%80%81%20%3CSTRONG%3ENXP%20GCC%20for%20Arm%20Embedded%20Processors%20v10.2%20build%201728%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%82%E5%BF%98%E3%82%8C%E3%81%AA%E3%81%84%E3%81%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSTRONG%3E%E3%81%AB%E3%82%88%E3%82%8B%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3CSTRONG%3ES32DS%E3%81%AE%E6%8B%A1%E5%BC%B5%E6%A9%9F%E8%83%BD%E3%81%A8%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%83%AD%E3%83%93%E3%83%B3%3CBR%20%2F%3E-------------------------------------------------------------------------------%3CBR%20%2F%3E%E6%B3%A8%E8%A8%98%EF%BC%9A%3CBR%20%2F%3E%E3%81%93%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8C%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E8%B3%AA%E5%95%8F%E3%81%B8%E3%81%AE%E5%9B%9E%E7%AD%94%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%80%8C%E8%A7%A3%E6%B1%BA%E7%AD%96%E3%81%A8%E3%81%97%E3%81%A6%E6%89%BF%E8%AA%8D%E3%80%8D%E3%83%9C%E3%82%BF%E3%83%B3%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%EF%BC%81%3C%2FP%3E%0A%3CP%3E-%20%E6%9C%80%E5%BE%8C%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%8B%E3%82%897%E9%80%B1%E9%96%93%E3%81%AF%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E3%83%95%E3%82%A9%E3%83%AD%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E4%BB%A5%E9%99%8D%E3%81%AE%E8%BF%94%E4%BF%A1%E3%81%AF%E7%84%A1%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E5%BE%8C%E6%97%A5%E3%80%81%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E8%B3%AA%E5%95%8F%E3%81%8C%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E9%96%89%E3%81%98%E3%82%89%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%AC%E3%83%83%E3%83%89%E3%82%92%E5%8F%82%E7%85%A7%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E-------------------------------------------------------------------------------%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
