S32M276 - Constant 1s reset Loop (MCU_HSE_SWT_RST_RESET) using RTD 6.0.0
已解决
跳至解决方案
1,044 次查看
Miguel_Marquez_Schaeffler
We are experiencing a continuous reset loop on both a custom board based on the S32M276 and in the official NXP development board using RTD 6.0.0.
Observed Behavior:
When the JTAG debugger is connected, the application runs correctly without any unexpected resets.
Upon reconnecting the debugger and inspecting the reset reason via the MCU/RGM status registers, the reset cause is identified as: MCU_HSE_SWT_RST_RESET.
The reset counter associated with the HSE Watchdog (HSE_WDT) increments after every cycle.
After disconnecting the debugger and doing a power cycle the device enters a reset loop approximately every 1 second.
Current Configuration:
    MCU: S32M276
    RTD Version: 6.0.0
- Could you please clarify the specific trigger for MCU_HSE_SWT_RST_RESET?
- What is the recommended procedure in RTD 6.0.0 to either disable this HSE-managed reset or properly service the WDT?
- Miguel Marquez
标记 (4)
1 解答
958 次查看
The solution was to prescale the HSE Clock from 120MHz to 60MHz.
在原帖中查看解决方案
3 回复数
981 次查看
Julián_AragónM
Hi @Miguel_Marquez_Schaeffler,
Thank you for the detailed explanation, along with the additional debug information.
From your description, this sounds like a clock configuration issue. Usually, this behavior happens when clock ratios are not followed: [s32k312]Read reset reason by RTD function, HSE_SWT_RST is occurred after a functional reset. - NXP ...
Could you please confirm you've followed the clocking modes as detailed in chapter 21.7.2 from the S32M27XRM? Specifically, check HSE_CLK configuration: Solved: S32K312 flexcan example not running on Power reset - NXP Community.
Julián
1,031 次查看
After further research on the forums we believe this information might be useful to debug the issue: (This is with the debugger connected)
UT0 REGISTER VALUE
DCMUTS VALUE
UTEST MEMORY START:
959 次查看
%3CLINGO-SUB%20id%3D%22lingo-sub-2350938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M276-%E4%BD%BF%E7%94%A8%20RTD%206.0.0%20%E7%9A%84%E6%81%92%E5%AE%9A%201%20%E7%A7%92%E9%87%8D%E7%BD%AE%E5%BE%AA%E7%8E%AF%20(MCU_HSE_SWT_RST_RESET)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350938%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E5%9C%A8%E5%9F%BA%E4%BA%8E%20S32M276%20%E7%9A%84%E5%AE%9A%E5%88%B6%E6%9D%BF%E5%92%8C%E4%BD%BF%E7%94%A8%20RTD%206.0.0%20%E7%9A%84%E6%81%A9%E6%99%BA%E6%B5%A6%E5%AE%98%E6%96%B9%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E9%83%BD%E9%81%87%E5%88%B0%E4%BA%86%E6%8C%81%E7%BB%AD%E7%9A%84%20RESET%20%E5%BE%AA%E7%8E%AF%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A7%82%E5%AF%9F%E5%88%B0%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%9A%E8%BF%9E%E6%8E%A5%20JTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%3CBR%20%2F%3E%E6%97%B6%EF%BC%8C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E8%BF%90%E8%A1%8C%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%BB%BB%E4%BD%95%E6%84%8F%E5%A4%96%3C%2FSPAN%3ERESET%E3%80%82%3CSPAN%3E%E9%87%8D%E6%96%B0%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%E5%B9%B6%E9%80%9A%E8%BF%87%20MCU%2FRGM%20%E7%8A%B6%E6%80%81%E5%AF%84%E5%AD%98%E5%99%A8%E6%A3%80%E6%9F%A5%E5%A4%8D%E4%BD%8D%E5%8E%9F%E5%9B%A0%E5%90%8E%EF%BC%8C%E5%A4%8D%E4%BD%8D%E5%8E%9F%E5%9B%A0%E8%A2%AB%E7%A1%AE%E5%AE%9A%E4%B8%BA%EF%BC%9AMCU_HSE_SWT_RST_RESE_SWT_RST_RESET%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E4%B8%8E%20HSE%20%E7%9C%8B%E9%97%A8%E7%8B%97%20(HSE_WDT)%20%E7%9B%B8%E5%85%B3%E7%9A%84%20RESET%20%E8%AE%A1%E6%95%B0%E5%99%A8%E5%9C%A8%E6%AF%8F%E4%B8%AA%E5%91%A8%E6%9C%9F%E5%90%8E%E9%83%BD%E4%BC%9A%E5%A2%9E%E5%8A%A0%E3%80%82%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%96%AD%E5%BC%80%E8%B0%83%E8%AF%95%E5%99%A8%E8%BF%9E%E6%8E%A5%E5%B9%B6%E9%87%8D%E6%96%B0%E9%80%9A%E7%94%B5%E5%90%8E%EF%BC%8C%3C%2FSTRONG%3E%E8%AE%BE%E5%A4%87%E5%A4%A7%E7%BA%A6%E6%AF%8F%201%20%E7%A7%92%E8%BF%9B%E5%85%A5%E4%B8%80%E6%AC%A1RESET%E5%BE%AA%E7%8E%AF%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E5%BD%93%E5%89%8D%E9%85%8D%E7%BD%AE%EF%BC%9A%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MCU%3A%20S32M276%3CBR%20%2F%3E%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RTD%20%E7%89%88%E6%9C%AC%3A%206.0.0%3CBR%20%2F%3E%3CBR%20%2F%3E-%E4%BD%A0%E8%83%BD%E5%90%A6%E6%BE%84%E6%B8%85%E4%B8%80%E4%B8%8B%20MCU_HSE_SWT_RST_RESET%20%E7%9A%84%E5%85%B7%E4%BD%93%E8%A7%A6%E5%8F%91%E4%BF%A1%E5%8F%B7%EF%BC%9F%3CBR%20%2F%3E-%E5%9C%A8%20RTD%206.0.0%20%E4%B8%AD%EF%BC%8C%E7%A6%81%E7%94%A8%E6%AD%A4%20HSE%20%E7%AE%A1%E7%90%86%E7%9A%84%20RESET%20%E6%88%96%E6%AD%A3%E7%A1%AE%E7%BB%B4%E6%8A%A4%20WDT%20%E7%9A%84%E6%8E%A8%E8%8D%90%E7%A8%8B%E5%BA%8F%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E-%20%E7%B1%B3%E6%A0%BC%E5%B0%94-%E9%A9%AC%E5%B0%94%E5%85%8B%E6%96%AF%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32M276%20-%20Constant%201s%20reset%20Loop%20(MCU_HSE_SWT_RST_RESET)%20using%20RTD%206.0.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350945%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%BB%8F%E8%BF%87%E5%9C%A8%E8%AE%BA%E5%9D%9B%E4%B8%8A%E7%9A%84%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%A0%94%E7%A9%B6%EF%BC%8C%E6%88%91%E4%BB%AC%E8%AE%A4%E4%B8%BA%E8%BF%99%E4%BA%9B%E4%BF%A1%E6%81%AF%E5%8F%AF%E8%83%BD%E6%9C%89%E5%8A%A9%E4%BA%8E%E8%B0%83%E8%AF%95%E9%97%AE%E9%A2%98%EF%BC%9A%EF%BC%88%E8%BF%99%E6%98%AF%E5%9C%A8%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%89%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Eut0%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%80%BC%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382345iBAC64866E4B3282A%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20alt%3D%22Miguel_Marquez_Schaeffler_0-1776194807760.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EDCMUTS%20%E4%BB%B7%E5%80%BC%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382346iACC18EA7B5C0287F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20alt%3D%22Miguel_Marquez_Schaeffler_1-1776194830840.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Eutest%20%E5%86%85%E5%AD%98%E5%90%AF%E5%8A%A8%EF%BC%9A%20%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382347i344890CCB39508A3%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20alt%3D%22Miguel_Marquez_Schaeffler_2-1776194844252.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2351766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32M276%20-%20Constant%201s%20reset%20Loop%20(MCU_HSE_SWT_RST_RESET)%20using%20RTD%206.0.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2351766%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F261685%22%20target%3D%22_blank%22%3E%40Miguel_Marquez_Schaeffler%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%AF%A6%E7%BB%86%E8%A7%A3%E9%87%8A%E5%92%8C%E8%A1%A5%E5%85%85%E8%B0%83%E8%AF%95%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E4%BD%A0%E7%9A%84%E6%8F%8F%E8%BF%B0%EF%BC%8C%E8%BF%99%E5%90%AC%E8%B5%B7%E6%9D%A5%E5%83%8F%E6%98%AF%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E9%97%AE%E9%A2%98%E3%80%82%E9%80%9A%E5%B8%B8%EF%BC%8C%E5%BD%93%E4%B8%8D%E9%81%B5%E5%BE%AA%E6%97%B6%E9%92%9F%E6%AF%94%E7%8E%87%E6%97%B6%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%8F%91%E7%94%9F%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2Fs32k312-Read-reset-reason-by-RTD-function-HSE-SWT-RST-is%2Ftd-p%2F1972653%22%20target%3D%22_blank%22%3E%5Bs32k312%5D%20RTD%20%E5%87%BD%E6%95%B0%E8%AF%BB%E5%8F%96%20RESET%20%E5%8E%9F%E5%9B%A0%EF%BC%8CHSE_SWT_RST%20%E5%8F%91%E7%94%9F%E5%9C%A8%E5%8A%9F%E8%83%BD%20RESET%20%E4%B9%8B%E5%90%8E%E3%80%82-%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%A1%AE%E8%AE%A4%E6%82%A8%E6%98%AF%E5%90%A6%E9%81%B5%E5%BE%AA%E4%BA%86%20S32M27XRM%20%E7%AC%AC%2021.7.2%20%E7%AB%A0%E4%B8%AD%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%E7%9A%84%E6%97%B6%E9%92%9F%E6%A8%A1%E5%BC%8F%EF%BC%9F%E5%85%B7%E4%BD%93%E8%80%8C%E8%A8%80%EF%BC%8C%E8%AF%B7%E6%9F%A5%E7%9C%8B%20HSE_CLK%20%E9%85%8D%E7%BD%AE%EF%BC%9A%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K%2FS32K312-flexcan-example-not-running-on-Power-reset%2Fm-p%2F1802558%22%20target%3D%22_blank%22%3E%E5%B7%B2%E8%A7%A3%E5%86%B3%EF%BC%9AS32K312%20flexcan%20%E7%A4%BA%E4%BE%8B%E6%9C%AA%E5%9C%A8%E7%94%B5%E6%BA%90%20RESET%20%E6%97%B6%E8%BF%90%E8%A1%8C%E2%80%94%E2%80%94%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EJuli%C3%A1n%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2352517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32M276%20-%20Constant%201s%20reset%20Loop%20(MCU_HSE_SWT_RST_RESET)%20using%20RTD%206.0.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2352517%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%E6%98%AF%E5%B0%86%20HSE%20%E6%97%B6%E9%92%9F%E7%9A%84%E9%A2%91%E7%8E%87%E4%BB%8E%20120MHz%20%E6%8F%90%E5%89%8D%E5%88%B0%2060MHz%E3%80%82%20%3C%2FP%3E%3C%2FLINGO-BODY%3E
