Questions about NXP IC S32M276CHABMKHSR - GDU function
Ted_Qiao
Hi NXP technicians,
I encountered one problem about using the GDU function of S32M276CHABMKHSR.
I want to measure the phase-voltage by HSX pins while motor is stopping.
The phase-voltage will be supplied with [DO-EN-MOT-DIAG] set to high-level, If the motor is not connected, only W-phase-voltage could be detected by HS2 pin.
but in my measurement, all HS0, HS1, HS2 detected the voltage similar to KL30-F(battery voltage) when motor is not connected.
I figure out the reason is that HGX is output voltage similar to KL30-F then the voltage will go through Vgs resistor(R604, R609, R614) to supply the phase-voltage.
So my question is that how could I do the setting to make the High-side gate voltage and Low-side gate voltage to [0] voltage while GDU module is Enabled. Then I want to use the HSX pin to measure the phase-voltage.
*You could take the reference to the BLDC driver circuit as attached PDF file.
if anything unclear, pls. contact to me.
Looking forward to your reply. Thanks and have a nice day!
BR, Ted
danielmartynek
Hello @Ted_Qiao,
I'm sorry for the delay; we experienced a technical issue with our community‑tracking system.
Is this question still open?
Thank you,
Ted_Qiao
I forgot the attachement.
%3CLINGO-SUB%20id%3D%22lingo-sub-2333979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EQuestions%20about%20NXP%20IC%20S32M276CHABMKHSR%20-%20GDU%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333979%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20NXP%20technicians%2C%3C%2FP%3E%3CP%3EI%20encountered%20one%20problem%20about%20using%20the%20GDU%20function%20of%26nbsp%3BS32M276CHABMKHSR.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20want%20to%20measure%20the%20phase-voltage%20by%20HSX%20pins%20while%20motor%20is%20stopping.%3C%2FP%3E%3CP%3EThe%20phase-voltage%20will%20be%20supplied%20with%20%5BDO-EN-MOT-DIAG%5D%20set%20to%20high-level%2C%20If%20the%20motor%20is%20not%20connected%2C%20only%20W-phase-voltage%20could%20be%20detected%20by%20HS2%20pin.%3C%2FP%3E%3CP%3Ebut%20in%20my%20measurement%2C%20all%20HS0%2C%20HS1%2C%20HS2%20detected%20the%20voltage%20similar%20to%20KL30-F(battery%20voltage)%20when%20motor%20is%20not%20connected.%3C%2FP%3E%3CP%3EI%20figure%20out%20the%20reason%20is%20that%20HGX%20is%20output%20voltage%20similar%20to%20KL30-F%20then%20the%20voltage%20will%20go%20through%20Vgs%20resistor(R604%2C%20R609%2C%20R614)%20to%20supply%20the%20phase-voltage.%3C%2FP%3E%3CP%3ESo%20my%20question%20is%20that%20how%20could%20I%20do%20the%20setting%20to%20make%20the%20High-side%20gate%20voltage%20and%20Low-side%20gate%20voltage%20to%20%5B0%5D%20voltage%20while%20GDU%20module%20is%20Enabled.%20Then%20I%20want%20to%20use%20the%20HSX%20pin%20to%20measure%20the%20phase-voltage.%3C%2FP%3E%3CP%3E*You%20could%20take%20the%20reference%20to%20the%20BLDC%20driver%20circuit%20as%20attached%20PDF%20file.%3C%2FP%3E%3CP%3Eif%20anything%20unclear%2C%20pls.%20contact%20to%20me.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ELooking%20forward%20to%20your%20reply.%20Thanks%20and%20have%20a%20nice%20day!%3C%2FP%3E%3CP%3EBR%2C%20Ted%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2333980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Questions%20about%20NXP%20IC%20S32M276CHABMKHSR%20-%20GDU%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2333980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20forgot%20the%20attachement.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2348073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Questions%20about%20NXP%20IC%20S32M276CHABMKHSR%20-%20GDU%20function%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256881%22%20target%3D%22_blank%22%3E%40Ted_Qiao%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3EI'm%20sorry%20for%20the%20delay%3B%20we%20experienced%20a%20technical%20issue%20with%20our%20community%E2%80%91tracking%20system.%3CBR%20%2F%3EIs%20this%20question%20still%20open%3F%3C%2FP%3E%0A%3CP%3EThank%20you%2C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
