S32M LIN Stack compilation errors
3,702件の閲覧回数
hns80
Senior Contributor I
I am using S32DS 3.5 and S32M24 RTD 2.0.0 and installed the S32K1_S32M24X_LINSTACK_RTM_1_0_2_D2308_updatesite.zip.
I imported the master and slave examples, fixed the backslash problem in the mex file (<setting name="LDFRelativePath" value="src\LIN21.ldf"/>), and generated the configuration code.
Neither project will build.
The slave code has these errors:
Description Resource Path Location Type
'LinIf_Channel_State' undeclared (first use in this function) lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 520 C/C++ Problem
'LINIF_IDLE' undeclared (first use in this function); did you mean 'LINIF_CODE'? lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 520 C/C++ Problem
Field 'lin_baudrate_adjusted_flg' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 199 Semantic Error
Field 'lin_max_frame_res_timeout_val' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 193 Semantic Error
Field 'lin_protocol_state' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 172 Semantic Error
Field 'lin_protocol_state' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 438 Semantic Error
Field 'lin_protocol_state' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 443 Semantic Error
Field 'lin_protocol_state' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 488 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 128 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 146 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 176 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 181 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 302 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 411 Semantic Error
Field 'lin_virtual_interface' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 489 Semantic Error
Field 'max_idle_timeout_cnt' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 528 Semantic Error
Field 'response_buffer_ptr' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 443 Semantic Error
Field 'response_length' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 438 Semantic Error
implicit declaration of function 'OsIf_ResumeAllInterrupts' [-Werror=implicit-function-declaration] lin_commontl_proto.c /Lin_Master_S32M244_Example_DS/stacks/lin/src line 1241 C/C++ Problem
implicit declaration of function 'OsIf_ResumeAllInterrupts' [-Werror=implicit-function-declaration] lin_commontl_proto.c /Lin_Slave_S32M244_Example_DS/stacks/lin/src line 1241 C/C++ Problem
implicit declaration of function 'OsIf_SuspendAllInterrupts' [-Werror=implicit-function-declaration] lin_commontl_proto.c /Lin_Master_S32M244_Example_DS/stacks/lin/src line 1172 C/C++ Problem
implicit declaration of function 'OsIf_SuspendAllInterrupts' [-Werror=implicit-function-declaration] lin_commontl_proto.c /Lin_Slave_S32M244_Example_DS/stacks/lin/src line 1172 C/C++ Problem
make: *** [stacks/lin/lin_dal/src/subdir.mk:20: stacks/lin/lin_dal/src/lin_dal.o] Error 1 Lin_Slave_S32M244_Example_DS C/C++ Problem
make: *** [stacks/lin/src/subdir.mk:36: stacks/lin/src/lin_commontl_proto.o] Error 1 Lin_Master_S32M244_Example_DS C/C++ Problem
make: *** [stacks/lin/src/subdir.mk:36: stacks/lin/src/lin_commontl_proto.o] Error 1 Lin_Slave_S32M244_Example_DS C/C++ Problem
make: *** Waiting for unfinished jobs.... Lin_Master_S32M244_Example_DS C/C++ Problem
make: *** Waiting for unfinished jobs.... Lin_Slave_S32M244_Example_DS C/C++ Problem
Symbol 'LinIf_Channel_State' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 520 Semantic Error
Symbol 'LINIF_IDLE' could not be resolved lin_dal.c /Lin_Slave_S32M244_Example_DS/stacks/lin/lin_dal/src line 520 Semantic Error
The master code has fewer errors:
How can these errors be resolved?
3,634件の閲覧回数
hns80
I deleted both projects completely from my workspace, then re-imported the Lin_Slave and Lin_Master projects. Before opening the configurator, I fixed the backslash problem on the LDF source line mentioned in the original post.
I then opened the configurator, updated the code, and was able to build successfully.
Why is this line of the configurator consistently broken across all versions of this code? I see the same problem in the S32K118 implementation.
2 返答(返信)
3,695件の閲覧回数
hns80
I needed to add an include to lin_commontl_proto.c for the master and slave code:
#include "OsIf_Internal.h"
The master code will build now, but the slave code still has errors:
1. LINIF_IDLE is not defined
2. stacks/lin/lin_dal/src/lin_dal.c:520:23: error: 'LinIf_Channel_State' undeclared
3,635件の閲覧回数
hns80
%3CLINGO-SUB%20id%3D%22lingo-sub-2067519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32M%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067519%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ES32DS%203.5%20%E3%81%A8%20S32M24%20RTD%202.0.0%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81S32K1_S32M24X_LINSTACK_RTM_1_0_2_D2308_updatesite.zip%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%81%AE%E4%BE%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81mex%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%B9%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88%3CSETTING%20name%3D%22LDFRelativePath%22%20value%3D%22src%26lt%3BSTRONG%26gt%3B%5C%26lt%3B%2FSTRONG%26gt%3BLIN21.ldf%22%3E%3C%2FSETTING%3E)%E3%80%81%E3%81%9D%E3%81%97%E3%81%A6%E3%80%81%E8%A8%AD%E5%AE%9A%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%A1%E3%82%89%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%82%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%AC%E6%98%8E%20Resource%20Path%20Location%20Type%3CBR%20%2F%3E'LinIf_Channel_State'%20undeclared%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20520%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E'LINIF_IDLE'%20%E6%9C%AA%E5%AE%A3%E8%A8%80%20(%E3%81%93%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%A7%E6%9C%80%E5%88%9D%E3%81%AB%E4%BD%BF%E7%94%A8)%E3%80%82%E3%80%8CLINIF_CODE%E3%80%8D%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A0%E3%81%A3%E3%81%9F%E3%81%AE%3Flin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20520%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_baudrate_adjusted_flg'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20199%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_max_frame_res_timeout_val'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20193%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_protocol_state'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20172%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_protocol_state'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20438%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_protocol_state'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20443%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_protocol_state'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20488%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20128%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20146%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20176%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20181%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20302%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20411%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'lin_virtual_interface'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20489%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'max_idle_timeout_cnt'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20528%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'response_buffer_ptr'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20443%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%83%95%E3%82%A3%E3%83%BC%E3%83%AB%E3%83%89%20'response_length'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20438%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_ResumeAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Master_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201241%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_ResumeAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201241%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_SuspendAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Master_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201172%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_SuspendAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201172%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Emake%3A%20***%20%5Bstacks%2Flin%2Flin_dal%2Fsrc%2Fsubdir.mk%3A20%3Astacks%2Flin%2Flin_dal%2Fsrc%2Flin_dal.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%20Lin_Slave_S32M244_Example_DS%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Emake%3A%20***%20%5Bstacks%2Flin%2Fsrc%2Fsubdir.mk%3A36%3A%20stacks%2Flin%2Fsrc%2Flin_commontl_proto.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%20Lin_Master_S32M244_Example_DS%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Emake%3A%20***%20%5Bstacks%2Flin%2Fsrc%2Fsubdir.mk%3A36%3A%20stacks%2Flin%2Fsrc%2Flin_commontl_proto.o%5D%E3%82%A8%E3%83%A9%E3%83%BC%201%20Lin_Slave_S32M244_Example_DS%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Emake%3A%20***%20%E6%9C%AA%E5%AE%8C%E6%88%90%E3%81%AE%E4%BB%95%E4%BA%8B%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%80%82Lin_Master_S32M244_Example_DS%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3Emake%3A%20***%20%E6%9C%AA%E5%AE%8C%E6%88%90%E3%81%AE%E4%BB%95%E4%BA%8B%E3%82%92%E5%BE%85%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99...%E3%80%82Lin_Slave_S32M244_Example_DS%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%20'LinIf_Channel_State'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20520%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3CBR%20%2F%3E%E3%82%B7%E3%83%B3%E3%83%9C%E3%83%AB%20'LINIF_IDLE'%20%E3%82%92%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%20lin_dal.c%2FLin_Slave_S32M244_Example_DS%2Fstacks%2Flin%2Flin_dal%2Fsrc%20520%20%E8%A1%8C%E7%9B%AE%20%E3%82%BB%E3%83%9E%E3%83%B3%E3%83%86%E3%82%A3%E3%83%83%E3%82%AF%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%BB%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E5%B0%91%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E8%AA%AC%E6%98%8E%20Resource%20Path%20Location%20Type%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_ResumeAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Master_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201241%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3CBR%20%2F%3E%E9%96%A2%E6%95%B0%20'OsIf_SuspendAllInterrupts'%20%E3%81%AE%E6%9A%97%E9%BB%99%E5%AE%A3%E8%A8%80%20%5B-Werror%3D%E6%9A%97%E9%BB%99%E3%81%AE%E9%96%A2%E6%95%B0%E5%AE%A3%E8%A8%80%5D%20lin_commontl_proto.c%2FLin_Master_S32M244_Example_DS%2Fstacks%2Flin%2Fsrc%201172%20%E8%A1%8C%E7%9B%AE%20C%2FC%2B%2B%20%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A7%A3%E6%B1%BA%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2072064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32M%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2072064%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%AF%E3%83%BC%E3%82%AF%E3%82%B9%E3%83%9A%E3%83%BC%E3%82%B9%E3%81%8B%E3%82%89%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%AE%8C%E5%85%A8%E3%81%AB%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81Lin_Slave%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A8Lin_Master%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%86%8D%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8F%E5%89%8D%E3%81%AB%E3%80%81%E5%85%83%E3%81%AE%E6%8A%95%E7%A8%BF%E3%81%A7%E8%AA%AC%E6%98%8E%E3%81%97%E3%81%9FLDF%E3%82%BD%E3%83%BC%E3%82%B9%E8%A1%8C%E3%81%AE%E3%83%90%E3%83%83%E3%82%AF%E3%82%B9%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%9D%E3%81%AE%E5%BE%8C%E3%80%81%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E9%96%8B%E3%81%8D%E3%80%81%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E6%9B%B4%E6%96%B0%E3%81%97%E3%81%A6%E3%80%81%E7%84%A1%E4%BA%8B%E3%81%AB%E3%83%93%E3%83%AB%E3%83%89%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B3%E3%83%B3%E3%83%95%E3%82%A3%E3%82%AE%E3%83%A5%E3%83%AC%E3%83%BC%E3%82%BF%E3%83%BC%E3%81%AE%E3%81%93%E3%81%AE%E8%A1%8C%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%A7%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6%E5%A3%8A%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%3FS32K118%E3%81%AE%E5%AE%9F%E8%A3%85%E3%81%A7%E3%82%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2067524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32M%20LIN%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2067524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%A8%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AE%E3%81%9F%E3%82%81%E3%81%ABlin_commontl_proto.c%E3%81%AB%E3%82%A4%E3%83%B3%E3%82%AF%E3%83%AB%E3%83%BC%E3%83%89%E3%82%92%E8%BF%BD%E5%8A%A0%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3E%23include%20%E3%80%8COsIf_Internal.h%E3%80%8D%3C%2FP%3E%3CP%3E%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AF%E3%83%93%E3%83%AB%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%AF%E3%81%BE%E3%81%A0%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1.%20LINIF_IDLE%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FP%3E%3CP%3E2.%20stacks%2Flin%2Flin_dal%2Fsrc%2Flin_dal.c%3A520%3A23%3A%E3%82%A8%E3%83%A9%E3%83%BC%3A%20'LinIf_Channel_State'%20%E6%9C%AA%E5%AE%A3%E8%A8%80%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
