unified_bootloader_framework  for S32
chaitanya_kalyani
We are using unified_bootloader_framework  for S32K bootloader code using S32K116 Micro and for one of application we have requested LIN based bootloader. After integrating with application and your NxP Open Bus tool it is working fine.
Shall we modify the LIN bootloader code to match our internal tools and concept?
once it is proved out/working fine shall we use same for our production as free?
Thank you in advance.
lukaszadrapa
please notice that it is demo code only which is provided as is with no guarantees and no support. You can use it as a starting point to develop your own solution. It's completely up to you.
Lukas
lukaszadrapa
Lukas
