s32k144 ADC processor expert
2,465 次查看
sushma
Hello
I want to configure ADC using processor expert and below is the code I have tried and I'm not able to get the values.
I have connected PTA0( ADC0_SE0 - convertAdcChan(0)) to 3.3V onboard and I'm not able to get the reading. I have attached the code and screenshots. Kindly tell me where I may be going wrong.
Thank you.
标签 (1)
标记 (1)
2 回复数
2,213 次查看
dianabatrlova
I have tested your code. Please select the Input channel ADC_INPUTCHAN_EXT0 in the adConv1:adc. After that, you will get the correct values.
I believe it helps you.
Diana
2,213 次查看
sushma
Thank you Diana, this helped. Can you look into this https://community.nxp.com/thread/496626  and give me solution.
