s32k sai mclk problem
1,250件の閲覧回数
nullnullnull
a case :
sample rate 96k  tdm 8channel 32bit per word
bclk will be 24.576mhz
then, mclk should be 49.512mhz
why the frequency of mclk cannot be more than 24.576mhz in datasheet?
1,206件の閲覧回数
Robin_Shen
There is BYP Bit Clock Bypass in 75.6.1.6 Transmit Configuration 2 (TCR2) :
If set, it allows to bypass the bit clock divider, thus BCLK is divided by 1 of audio master clock.
Robin
