s32k sai mclk problem
nullnullnull
a case :
sample rate 96k  tdm 8channel 32bit per word
bclk will be 24.576mhz
then, mclk should be 49.512mhz
why the frequency of mclk cannot be more than 24.576mhz in datasheet?
Robin_Shen
There is BYP Bit Clock Bypass in 75.6.1.6 Transmit Configuration 2 (TCR2) :
If set, it allows to bypass the bit clock divider, thus BCLK is divided by 1 of audio master clock.
Robin
