s32ds lin stack component inspector error
2,059 次查看
skb
hi, i tested lin stack example for using s32k116 evb
recently, i got a ldf file from internet
when i add that to my project folder, and loading in lin stack component inspector,
some error message is occurred.
list of signal, Signal is no carried by any frmae!
How can i do?
标记 (3)
2,040 次查看
PetrS
a message from LIN SW expert...
The Lin protocol will communicate by transferring frame in the bus. Each frame will contain one or more signal. So if one signal which is not a part of any frame in the LDF, then it should not be exist in the LDF file(should be removed from LDF file).
BR, Petr
