s32K344 gmac receive data error
2,165 次查看
peter_yang
  • I used S32K344 and SJA1105 for the development of network communication and MII interface. The actual debugging found that the data received by the network card was abnormal. For example, the data actually sent by me was 0x34, 0x23, while the data received by the S32K344 network card was 0x33, 0x44, 0x22, 0x33. Every 4 bits are repeated. How do I fix this?
2 回复数
1,604 次查看
seanwinans710k19a
Were you able to solve the issue?
I am having a similar problem with a DP83848 PHY.
1,975 次查看
xuezi
@lukaszadrapa 我们碰到了一样的问题,请问如何解决?谢谢!
