output file (*.srec) is inconsistent
930 次查看
ligelige
I meet a problem. I complie files in ubuntu(gcc 6.3 arm32) and windows(gcc 6.3 arm32), and there is an inconsistent output file. A result like as:
Two file files are attached in the attachment.
There is a possibility if I configure s32ds and it is can be consistent.
Many thanks!
1 回复
899 次查看
jiri_kral
is your project working? What's the target device?
