memory map files
memory map files
4,990件の閲覧回数
zp001
There isn't any memory map configuration in the s32k3xxRM.pdf attachment S32K3xx_memory.xlsx.
I'm wondering know How can I get memory map infomation.
Thanks!
4 返答(返信)
4,986件の閲覧回数
danielmartynek
Hello @zp001,
I'm not sure what you mean.
What do you think is missing in the S32K3xx_memory.xlsx file?
BR, Daniel
4,841件の閲覧回数
Ricard_Castell
Hello @danielmartynek ,
I am facing the same problem. In the S32K3XXRM document there are several references across the text of this "attatched memory map file" (See image below).
However, there is no clue of this memory map file in the NXP web https://www.nxp.com/products/processors-and-microcontrollers/s32-automotive-platform/s32k-auto-gener... when you try to download the S32K3XXRM.pdf (See figure below).
Ricard
4,834件の閲覧回数
danielmartynek
Hi @Ricard_Castell,
What PDF reader do you use?
This is Adobe:
BR, Daniel
4,822件の閲覧回数
Ricard_Castell
Hi @danielmartynek ,
Thank you very much! I was opening the file with Chrome so I could not find those links.
Ricard
