jtag jflash program S32K314,no run.
luoboshu
1、用jtag接口,jflash 烧录S32K314的代码后,程序有时候无法运行。
2、用PE在S32DS中仿真是正常运行的。
danielmartynek
Hi @luoboshu,
There is too little information in the description to find the root cause.
What does it meas that it does not work?
There is nothing wrong on the screenshot you posted.
If it works with PE Micro / S32DS and not with J-link / JFlash, please contact SEGGER support.
Thank you,
danielmartynek
Hi @luoboshu,
Thank you,
