how to start with clock_ip_ReferencePoints
2,924件の閲覧回数
jimmy623
In S32k358, how can I use  already defined clk ?
Thanks!
2,799件の閲覧回数
danielmartynek
Hello @jimmy623,
I see, it is a bug in RTD 3.0.0, it has been fixed in RTD 4.0.0
9 返答(返信)
2,906件の閲覧回数
danielmartynek
Hello @jimmy623,
The references can be used by other RTD drivers.
Such as BaseNXP Osif Config, see below.
There is no list of drivers dependent on the clock reference points.
2,874件の閲覧回数
jimmy623
How can i use to LPUART driver ?
default Baud rate is 40M ,which mismatch to Reference design.
Thanks!
2,857件の閲覧回数
danielmartynek
Hello @jimmy623,
The LPUART modules are clocked either by AIPS_PLAT_CLK or AIPS_SLOW_CLK depending on the number of the instance, this cannot be changed. Refer to the RM.
2,855件の閲覧回数
jimmy623
This is a Bug?
2,853件の閲覧回数
danielmartynek
Which RTD version is it?
Thank you.
2,851件の閲覧回数
jimmy623
RTD AUTOSAR 4.7
2,849件の閲覧回数
danielmartynek
That is the Autosar version, I mean RTD version.
For example, in this version, it is correct:
2,803件の閲覧回数
jimmy623
I will check RTD 4.0 later
2,800件の閲覧回数
danielmartynek
Hello @jimmy623,
