how to create interrupt function in s32k148
2,773件の閲覧回数
sephangie
is there anyone who knows how to create interrupt function in s32k148 as following, IAR manual says CORTEX-M4 is not available to use _ _irq
extern  - -irq void abc_Interrupt(void);
appreciate your help!
2,764件の閲覧回数
Senlent
Hi@sephangie
   for example , create an interrupt for Port D(GPIO).
INT_SYS_InstallHandler(PORTD_IRQn, &PortD_Extern_ISR,  (isr_t*) 0);
INT_SYS_EnableIRQ(PORTD_IRQn);
void PortD_Extern_ISR(void)
 PINS_DRV_ClearPortIntFlagCmd(PORTD);
 There are many routines in the official SDK , for details, you can refer to the routines.
BR!
     Jim,
2 返答(返信)
2,765件の閲覧回数
Senlent
Hi@sephangie
BR!
     Jim,
2,755件の閲覧回数
sephangie
yes, sure I am going to find more in SDK, thank you! @Senlent
