how should i use ILas Notification Callback function in multi interface?
1,386 次查看
jylee3
When using ISELED 2 channels, do I need to use a separate event notification callback function
(typedef void (*ILaS_EventNotificationType) (ILaS_CommEventType eEventType, uint8 u8Strip);) for each channel?
1,322 次查看
Nhi_Nguyen
Hi @jylee3 ,
As you can see, the notification used configured at:
Channels is specific tab and Notification configuration is in generic tab.
As far as I know, you can define 1 notification for multiple channels and handle these channel into this function.
Nhi
标记 (1)
787 次查看
jylee3
Can the callback of the API (ILaS_Send_Cmd_Parallel) also be checked per channel?
标记 (1)
751 次查看
Nhi_Nguyen
Hi @jylee3 ,
Please create the new topic and tag Iseled to your topic. Someone is from Iseled team will reply your question.
Nhi
