how can l set interrupt priority on s32ds
已解决
跳至解决方案
5,106 次查看
jinshuaixu
Contributor V
           below is tow interrupt code ,if I want to set systick interrupt prioyity higher than wdog, who can tell me below code is right or wrong.?l an a new user ,firstly use S32K144 and S32DS.
           please give me code or example code,thank you .
/* Install IRQ handlers for WDOG and SysTick interrupts */
INT_SYS_InstallHandler(WDOG_EWM_IRQn, WDOG_ISR, (isr_t *)0);
INT_SYS_InstallHandler(SysTick_IRQn, SysTick_Handler, (isr_t *)0);
INT_SYS_SetPriority(WDOG_EWM_IRQn,0);
INT_SYS_SetPriority(SysTick_IRQn,1);
标签 (1)
1 解答
4,207 次查看
danielmartynek
The lower priority number, the higher priority level.
So in your code, the WDOG interrupt has higher priority then SysTick.
The code should be:
void WDOG_IRQ_handler(void) {
// do something
void SysTick_IRQ_Handler(void){
// do something
INT_SYS_InstallHandler(WDOG_EWM_IRQn, WDOG_IRQ_handler, (isr_t *)0);
INT_SYS_InstallHandler(SysTick_IRQn, SysTick_IRQ_Handler, (isr_t *)0);
INT_SYS_SetPriority(WDOG_EWM_IRQn, 1);
INT_SYS_SetPriority(SysTick_IRQn, 0);
INT_SYS_EnableIRQ(WDOG_EWM_IRQn);
INT_SYS_EnableIRQ(SysTick_IRQn);
在原帖中查看解决方案
1 回复
4,208 次查看
danielmartynek
The code should be:
// do something
// do something
