Data flash to emulated eeprom.
5,335 次查看
letseatorange
HELLO:
I want to use Data flash to emulated eeprom.but i find the EEEsize is always 0.I use this FLASH_DRV_DEFlashPartition() API to Divide the area,if something i shou do before use this API.
8 回复数
5,010 次查看
danielmartynek
Please refer to SDK RTM_1.0.0 examples.
The flash_partitioning code shows both the partitioning and use of the emulated EEPROM.
5,010 次查看
letseatorange
      I use the same method as this example, but it can't to partition. the EEEsize is always 0.
thanks
5,010 次查看
danielmartynek
Please check what version of the S32K144 you use.
The SDK is not compatible with the first version (N77P).
So If the example doesn't work, this could be the problem.
5,010 次查看
letseatorange
or other example can use to partirion the eeprom correctly
5,010 次查看
danielmartynek
Unfortunately, we don't have any example for partitioning.
5,010 次查看
letseatorange
thanks
5,010 次查看
letseatorange
My version is the first version (N77P), if there any other SDK support the first version?
5,010 次查看
danielmartynek
The S32K144(N77P) is compatible with SDK v.0.8.1. but it doesn't contain any example for partitioning.
