flash programming question
kmh48301
I am using s32k144 now.
Please Check this situation is bad for flash memory or not.
1. D-Flash is in erased state now.
2. Program Phrase the D-Flash base(address is 0x1000_0000) as "0xff_ff_ff_ff__ff_ff_ff_aa"
3. Then Program Phrase the right next of D-Flash base(address is 0x1000_0001)
as "0xff_ff_ff_ff__ff_ff_ff_aa". (same)
So the result of D-Flash : 0xff.......ff(all 1) and aa_aa" (last 2 bytes are only aa)
Is this possible? Does this behavior overstress the flash?
I know 0->0 transition is bad for flash.
But 1->1 program... is it okay?
Phillip
