hello,
I found BBF flag in the MSR of I2C (S32K314)cannot be cleared once it is set.
I tried to switch SDA and SLC to GPIO mode and pull up, and set the RST flag in MCR. but all failed.
any code can I refer to ?
depends which device is holding bus low, anyway you can refer to below thread for more info about bus recoveryhttps://community.nxp.com/t5/S32K/S32K-IIC-Communication-Error-Recovery/td-p/1618763
BR, Petr
