Using the MC34GD3000 Gate Driver with a 24 V BLDC Motor
MCmuhyeon0523
I am currently using the S32K144 BLDC/PMSM Development Kit, which includes the MC34GD3000 gate driver IC.
From the application circuit and documentation, it appears that the reference design is intended for a 12 V BLDC motor. However, the BLDC motor included with the development kit is actually a 24 V motor, which raised a few questions for me.
I would appreciate your advice on the following:
My understanding is that the MC34GD3000 gate driver itself operates from a 12 V gate-drive supply, while the inverter DC bus can be supplied with 24 V for driving a 24 V BLDC motor. Is this the correct way to use the MC34GD3000, or am I missing something?
Are there any voltage-related limitations or precautions when using the MC34GD3000 with a 24 V BLDC motor? For example, are there any recommended operating conditions, bootstrap considerations, or other design points that I should pay attention to?
If anyone has experience using this development kit or the MC34GD3000 with a 24 V motor, I would greatly appreciate your advice.
Thank you in advance!
Senlent
Hi@MCmuhyeon0523
 you can take a look this solution,
The MCSXTE2BK142 is a development board engineered for 3-phase Permanent Magnet (BLDC/PMSM) motor up to 800 W output at 24 V system or up to 400 W at 12 V system.
https://www.nxp.com/design/design-center/development-boards-and-designs/MCSXTE2BK142
%3CLINGO-SUB%20id%3D%22lingo-sub-2390852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EUsing%20the%20MC34GD3000%20Gate%20Driver%20with%20a%2024%20V%20BLDC%20Motor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390852%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3EI%20am%20currently%20using%20the%20S32K144%20BLDC%2FPMSM%20Development%20Kit%2C%20which%20includes%20the%20MC34GD3000%20gate%20driver%20IC.%3C%2FP%3E%3CP%3EFrom%20the%20application%20circuit%20and%20documentation%2C%20it%20appears%20that%20the%20reference%20design%20is%20intended%20for%20a%2012%20V%20BLDC%20motor.%20However%2C%20the%20BLDC%20motor%20included%20with%20the%20development%20kit%20is%20actually%20a%2024%20V%20motor%2C%20which%20raised%20a%20few%20questions%20for%20me.%3C%2FP%3E%3CP%3EI%20would%20appreciate%20your%20advice%20on%20the%20following%3A%3C%2FP%3E%3CP%3EMy%20understanding%20is%20that%20the%20MC34GD3000%20gate%20driver%20itself%20operates%20from%20a%2012%20V%20gate-drive%20supply%2C%20while%20the%20inverter%20DC%20bus%20can%20be%20supplied%20with%2024%20V%20for%20driving%20a%2024%20V%20BLDC%20motor.%20Is%20this%20the%20correct%20way%20to%20use%20the%20MC34GD3000%2C%20or%20am%20I%20missing%20something%3F%3CBR%20%2F%3EAre%20there%20any%20voltage-related%20limitations%20or%20precautions%20when%20using%20the%20MC34GD3000%20with%20a%2024%20V%20BLDC%20motor%3F%20For%20example%2C%20are%20there%20any%20recommended%20operating%20conditions%2C%20bootstrap%20considerations%2C%20or%20other%20design%20points%20that%20I%20should%20pay%20attention%20to%3F%3CBR%20%2F%3EIf%20anyone%20has%20experience%20using%20this%20development%20kit%20or%20the%20MC34GD3000%20with%20a%2024%20V%20motor%2C%20I%20would%20greatly%20appreciate%20your%20advice.%3C%2FP%3E%3CP%3EThank%20you%20in%20advance!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2390940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Using%20the%20MC34GD3000%20Gate%20Driver%20with%20a%2024%20V%20BLDC%20Motor%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2390940%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3EMCmuhyeon0523%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3Byou%20can%20take%20a%20look%20this%20solution%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EThe%20MCSXTE2BK142%20is%20a%20development%20board%20engineered%20for%203-phase%20Permanent%20Magnet%20(BLDC%2FPMSM)%20motor%20up%20to%20800%20W%20output%20at%2024%20V%20system%20or%20up%20to%20400%20W%20at%2012%20V%20system.%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FMCSXTE2BK142%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2FMCSXTE2BK142%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
