Use Touch Slider function on S32K116
2,153 次查看
liwei0225
Hi, NXP engineers,
    I used touch slider function on mcu s32k116, we have 6 electrode pads, two of them are used as slider function. Can you provide the document named Slider Application Quick Start Guide       mentioned in Document Number: AN_CSSWUG.I can't get it online. Thank you very much.
2,129 次查看
danielmartynek
Hello @liwei0225,
I sent you a private email, because the document is not public yet.
2,130 次查看
danielmartynek
Hello @liwei0225,
2,142 次查看
liwei0225
In addition, I use one ADC module ADC0 (because k116 only have one ADC module) to deal with one slider based on two electrode pads, do this method work? Because I have tried this method, but it seems affects the timer, so my i2c works unnormal.
