Undefined term in main code in pins and clock training project
ソリューションへジャンプ
4,712件の閲覧回数
SParihar
I am new to S32 Design Studio and am trying to build and debug Pins and Clock Training project using configuration tools. But the term "&Mcu_aClockConfigPB[0] " gives the error, undeclared (first use in this function) . I suspect a file which defines this term has not been generated but i have properly followed the steps in pdf training.
4,629件の閲覧回数
SParihar
The term was defined with a different name as Clock_Ip_aClockConfig.
3 返答(返信)
4,630件の閲覧回数
SParihar
4,651件の閲覧回数
Senlent
Hi@ethanhunt
You can export the project, and I can help you troubleshoot, or the easiest way is to troubleshoot the problem by referring to the routines provided in the IDE.
4,638件の閲覧回数
SParihar
i have provided the exapmle pdf and project folder
