Unable to get the make file path while compiling the project after installing the S32DS of V2.2
Dasari_Sumanth02
Julián_AragónM
Hi @Dasari_Sumanth02,
Is this an example imported from another version? Or was this created from scratch? This issue commonly appears when trying to compile an incompatible project.
Could you share this project in order to test this on my side?
Julián
