There happen some error When I use S32 DS open WDOG_Example
2,483件の閲覧回数
_simple_
I  use S32 Design Studio for ARM Version: 1.3  Build id: 170119,There happen some error When I use S32 DS open WDOG_Example? No such file or directory main.c /WDOG_Example/Sources line 60 C/C++ Problem,Who can help me solve this problem?
Thanks!
4 返答(返信)
2,320件の閲覧回数
raresvasile
It seems that PEx code was not generated. Please try to generate the configuration structures and file links by clicking on Project -> Generate Processor Expert Code.
Rares
2,320件の閲覧回数
_simple_
Thanks,According to what you said, I try it, But the problem still exists.
Thanks for your help
2,320件の閲覧回数
raresvasile
What version of the SDK are you using?
Can you attach the project?
2,320件の閲覧回数
_simple_
The SDK version is S32 Design Studio for ARM Version: 1.3
File->Import->S32DS Example Project
