The CRC Error of FlexCAN-S32K148
993件の閲覧回数
SONGTAOSI
In the RM of FlexCAN , the documentation says that the data frame contains CRC check, but as far as the program is concerned, it does not show. How do I verify the CRC check error interrupt?
Thanks!
975件の閲覧回数
Robin_Shen
Hi SONGTAOSI,
About how S32K1's FlexCAN detects CRC errors, please refer to About error and status register 1
About how to generate wrong CAN frames: If you have PCAN, you can refer to PCAN-View Error Generator - User Guide. If not, you can refer to: Configurable Error Generator for Controller Area
Network
Robin
