TempSense data is so weird..
rlaxortn
i am using s32k314, s32ds 3.6.1 Version.
i make a source code for reading MCU TempSense.
when i get data from MCU TempSense data, data is so weird..
before i use Adc_Sar_Ip_TempSenseGetTemp function, i use Adc_Sar_Ip_TempSenseEnable(1U).
reason parameter 1 is i use make TempSense adc channel in adc1 by adc config.
1. why data is so weird..?
2. do i have to do something?
3. when you see first pic, adc resolution is 14. so tempSens resolution is 14bit?????
thanks to help.
Tags (2)
Senlent
Hi@rlaxortn
In your last answer, you said "because MCU Supply voltage is 3.3V". Now you say "MCU VREFH is 5.0V". Are you serious?
In your configuration , the TempSense Voltage Supply is 0x53, that is 5.3V
the Adc Voltage Reference is 53->0x35->3.5V
We've been talking for so long and you keep making the same mistakes。
If your VREFH is 5V, then you should set both values to 0x50.
Secondly, to improve stability, you can set the following parameters to a larger value and test again.
Senlent
Hi@rlaxortn
Your ADC reference voltage is 3.2V?
rlaxortn
@Senlent
1. How can I know the supply voltage of Tempsense? Isn't the operating power of MCU the supply voltage of TEMPSense? or dose TempSense have other pin for getting Voltage like adc Channel?
2. because MCU Supply voltage is 3.3V. so i set TempSense Supply Voltage is 50(0x32)-> 3.2V.
3. anyway i test Tempsense Supply voltage, 0x50(5.0V), 0x15(1.5V), 0x33(3.3v).
when i set 0x50.
(TemperatureRaw is Integer value, mcuTempData is float for print)
ex) 2205 -> 0x89D
when i set 0x33(3.3V)
ex) 2537->0x9e9
when i set 0x15(1.5V)
ex) 5515->0x158B
Tags (2)
Senlent
Hi@rlaxortn
From the data you provided, your ADC sampling results fluctuate greatly. This should be due to some problems in your ADC sampling configuration.
1. Provide your project and I will help you check the ADC settings
2. Please confirm the ADC reference voltage on your current hardware and test the actual voltage of VREFH.
rlaxortn
@Senlent
1. it is difficult i give to you source code. but i can give adc configure by image capture. is it okay?
2. MCU VREFH is 5.0v, and VREFL is 0V.
rlaxortn
@Senlent
1. sorry, that is my mistake. VREF is 5.0V absolutely. so i already change value 0x50.
but result is same.
2. i gonna set larger than current value.
But I don't think that's a solution. i can catch the data shaking, but the values are weird.
you know previous pics, temperature is over 150 at least.
Tags (2)
Senlent
Hi@rlaxortn
What's your RTD version is?
rlaxortn
@Senlent
i check hardware by hardware engineer. so i knew Data is unstable.
although i supply vref voltage is 5.0V,  vref is unstable (4.1V~ 5.8V).
RTD Version is 4.0.0.
thanks to help.
Senlent
Hi@rlaxortn
Senlent
Hi@rlaxortn
Just to correct myself, there were some errors in my answer.
The data format used was S11.4.
Therefore, the actual value = original 16-bit signed number ÷ 16
For example:
1.0x15 = 21 / 16 = 1.3125V
2.0x35 = 53 / 16 = 3.3125V
3.0x50 = 80 / 16 = 5V
%3CLINGO-SUB%20id%3D%22lingo-sub-2135342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ETempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135342%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Ei%20am%20using%20s32k314%2C%20s32ds%203.6.1%20Version.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ei%20make%20a%20source%20code%20for%20reading%20MCU%20TempSense.%26nbsp%3B%3C%2FP%3E%3CP%3Ewhen%20i%20get%20data%20from%20MCU%20TempSense%20data%2C%20data%20is%20so%20weird..%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ebefore%20i%20use%26nbsp%3B%3CSPAN%3EAdc_Sar_Ip_TempSenseGetTemp%20function%2C%20i%20use%26nbsp%3BAdc_Sar_Ip_TempSenseEnable(1U).%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ereason%20parameter%201%20is%20i%20use%20make%20TempSense%20adc%20channel%20in%20adc1%20by%20adc%20config.%20%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347938i178E7773962DB844%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%223.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347939i6095AF7F3E259A1E%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%223.png%22%20alt%3D%223.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E3.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20508px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F347940i17C36C0936BE6889%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E1.%20why%20data%20is%20so%20weird..%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20do%20i%20have%20to%20do%20something%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3.%20when%20you%20see%20first%20pic%2C%20adc%20resolution%20is%2014.%20so%20tempSens%20resolution%20is%2014bit%3F%3F%3F%3F%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks%20to%20help.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136909%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ei%20check%20hardware%20by%20hardware%20engineer.%20so%20i%20knew%26nbsp%3B%3CSPAN%3EData%20is%20unstable.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Ealthough%20i%20supply%20vref%20voltage%20is%205.0V%2C%26nbsp%3B%20vref%20is%20unstable%20(4.1V~%205.8V).%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ERTD%20Version%20is%204.0.0.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ethanks%20to%20help.%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136312%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EWhat's%20your%20RTD%20version%20is%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136284%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20sorry%2C%20that%20is%20my%20mistake.%20VREF%20is%205.0V%20absolutely.%20so%20i%20already%20change%20value%200x50.%26nbsp%3B%3C%2FP%3E%3CP%3Ebut%20result%20is%20same.%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20i%20gonna%20set%20larger%20than%20current%20value.%26nbsp%3B%3C%2FP%3E%3CP%3EBut%20I%20don't%20think%20that's%20a%20solution.%20i%20can%20catch%20the%20data%20shaking%2C%20but%20the%20values%20are%20weird.%3C%2FP%3E%3CP%3Eyou%20know%20previous%20pics%2C%20temperature%20is%20over%20150%20at%20least.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136266%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EHi%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIn%20your%20last%20answer%2C%20you%20said%20%22%3CSTRONG%3Eb%3C%2FSTRONG%3E%3CSPAN%3E%3CSTRONG%3Eecause%20MCU%20Supply%20voltage%20is%203.3V%3C%2FSTRONG%3E%22%3C%2FSPAN%3E.%20Now%20you%20say%20%22%3CSTRONG%3EMCU%20VREFH%20is%205.0V%3C%2FSTRONG%3E%22.%20Are%20you%20serious%3F%3C%2FP%3E%0A%3CP%3EIn%20your%20configuration%20%2C%20the%20TempSense%20Voltage%20Supply%20is%200x53%2C%20that%20is%205.3V%3C%2FP%3E%0A%3CP%3Ethe%20Adc%20Voltage%20Reference%20is%2053-%26gt%3B0x35-%26gt%3B3.5V%3C%2FP%3E%0A%3CP%3EWe've%20been%20talking%20for%20so%20long%20and%20you%20keep%20making%20the%20same%20mistakes%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_1-1752817875816.png%22%20style%3D%22width%3A%20640px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348195i7419DBCFB0C6692B%2Fimage-dimensions%2F640x152%3Fv%3Dv2%22%20width%3D%22640%22%20height%3D%22152%22%20role%3D%22button%22%20title%3D%22Senlent_1-1752817875816.png%22%20alt%3D%22Senlent_1-1752817875816.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESenlent_1-1752817875816.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_2-1752818096266.png%22%20style%3D%22width%3A%20644px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348197i2E39EB64A9D89595%2Fimage-dimensions%2F644x87%3Fv%3Dv2%22%20width%3D%22644%22%20height%3D%2287%22%20role%3D%22button%22%20title%3D%22Senlent_2-1752818096266.png%22%20alt%3D%22Senlent_2-1752818096266.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESenlent_2-1752818096266.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EIf%20your%20VREFH%20is%205V%2C%20then%20you%20should%20set%20both%20values%20to%200x50.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ESecondly%2C%20to%20improve%20stability%2C%20you%20can%20set%20the%20following%20parameters%20to%20a%20larger%20value%20and%20test%20again.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Senlent_3-1752818335937.png%22%20style%3D%22width%3A%20692px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348199i898F8462730182C6%2Fimage-dimensions%2F692x102%3Fv%3Dv2%22%20width%3D%22692%22%20height%3D%22102%22%20role%3D%22button%22%20title%3D%22Senlent_3-1752818335937.png%22%20alt%3D%22Senlent_3-1752818335937.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESenlent_3-1752818335937.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%20it%20is%20difficult%20i%20give%20to%20you%20source%20code.%20but%20i%20can%20give%20adc%20configure%20by%20image%20capture.%20is%20it%20okay%3F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%221.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348187i954FD43E0F194DDF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%221.png%22%20alt%3D%221.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348186iBFBEAD13AEA56B69%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%222.png%22%20alt%3D%222.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20MCU%20VREFH%20is%205.0v%2C%20and%20VREFL%20is%200V.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136167%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Erlaxortn%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EFrom%20the%20data%20you%20provided%2C%20your%20ADC%20sampling%20results%20fluctuate%20greatly.%20This%20should%20be%20due%20to%20some%20problems%20in%20your%20ADC%20sampling%20configuration.%3CBR%20%2F%3E1.%20Provide%20your%20project%20and%20I%20will%20help%20you%20check%20the%20ADC%20settings%3CBR%20%2F%3E2.%20Please%20confirm%20the%20ADC%20reference%20voltage%20on%20your%20current%20hardware%20and%20test%20the%20actual%20voltage%20of%20VREFH.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2136117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2136117%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F188029%22%20target%3D%22_blank%22%3E%40Senlent%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1.%26nbsp%3B%3CSPAN%3EHow%20can%20I%20know%20the%20supply%20voltage%20of%20Tempsense%3F%20Isn't%20the%20operating%20power%20of%20MCU%20the%20supply%20voltage%20of%20TEMPSense%3F%20or%20dose%20TempSense%20have%20other%20pin%20for%20getting%20Voltage%20like%20adc%20Channel%3F%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2.%20because%20MCU%20Supply%20voltage%20is%203.3V.%20so%20i%20set%20TempSense%20Supply%20Voltage%20is%2050(0x32)-%26gt%3B%203.2V.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E3.%20anyway%20i%20test%20Tempsense%20Supply%20voltage%2C%200x50(5.0V)%2C%200x15(1.5V)%2C%200x33(3.3v).%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewhen%20i%20set%200x50.%3C%2FP%3E%3CP%3E(TemperatureRaw%20is%20Integer%20value%2C%20mcuTempData%20is%20float%20for%20print)%3C%2FP%3E%3CP%3Eex)%202205%20-%26gt%3B%200x89D%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%225volt.png%22%20style%3D%22width%3A%20633px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348146i25319E62C5A167FB%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%225volt.png%22%20alt%3D%225volt.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E5volt.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewhen%20i%20set%200x33(3.3V)%3C%2FP%3E%3CP%3E(TemperatureRaw%20is%20Integer%20value%2C%20mcuTempData%20is%20float%20for%20print)%3C%2FP%3E%3CP%3Eex)%202537-%26gt%3B0x9e9%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2233volt.png%22%20style%3D%22width%3A%20648px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348148i28674AB47505093D%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2233volt.png%22%20alt%3D%2233volt.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E33volt.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Ewhen%20i%20set%200x15(1.5V)%3C%2FP%3E%3CP%3Eex)%205515-%26gt%3B0x158B%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%2215volt.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348149iBF253347652C3114%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%2215volt.png%22%20alt%3D%2215volt.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E15volt.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2135567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2135567%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%40%3CSPAN%3Erlaxortn%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EYour%20ADC%20reference%20voltage%20is%203.2V%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%222025-07-17_15-29-30.png%22%20style%3D%22width%3A%20548px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F348002iCC990FA6B8C9CEDA%2Fimage-dimensions%2F548x413%3Fv%3Dv2%22%20width%3D%22548%22%20height%3D%22413%22%20role%3D%22button%22%20title%3D%222025-07-17_15-29-30.png%22%20alt%3D%222025-07-17_15-29-30.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E2025-07-17_15-29-30.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2394683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20TempSense%20data%20is%20so%20weird..%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2394683%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22mailto%3AHi%40rlaxortn%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%20target%3D%22_blank%22%3EHi%40rlaxortn%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EJust%20to%20correct%20myself%2C%20there%20were%20some%20errors%20in%20my%20answer.%3C%2FP%3E%0A%3CP%3EThe%20data%20format%20used%20was%20S11.4.%3C%2FP%3E%0A%3CP%3ETherefore%2C%20the%20actual%20value%20%3D%20original%2016-bit%20signed%20number%20%C3%B7%2016%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFor%20example%3A%3C%2FP%3E%0A%3CP%3E1.0x15%20%3D%2021%20%2F%2016%20%3D%201.3125V%3C%2FP%3E%0A%3CP%3E2.0x35%20%3D%2053%20%2F%2016%20%3D%203.3125V%3C%2FP%3E%0A%3CP%3E3.0x50%20%3D%2080%20%2F%2016%20%3D%205V%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
