T-Box 5G module
T-Box 5G module
2,793 次查看
tomasmrovec
We want to use T-Box Reference Design Board for V2x communication application. But I can't find any 5G modules with 5G & C-V2X AG55xQ from Quectel. There are connectors for 5G module on T-Box PCB.
So, there is some module for 5G available? From NXP or Quectel?
Thank you.
TM
2,753 次查看
parkermosman
I wanted to respond that we have the same question as the original poster (@tomasmrovec). We want to use the S32K3-T-BOX and plug in an off the shelf Quectel module. The schematic and hardware user's manual shows a Quectel module plugged into the TBOX via FX8-140P-SV headers. I can not find any reference to a Quectel device mounted on this type of evaluation header from Quectel or NXP. Is it possible for NXP to supply the precise part number for the fully packaged Quectel module assumed for use with this TBOX?
2,785 次查看
vicentegomez
I am not sure if this is what you need
https://www.nxp.com/products/radio-frequency/active-antenna-systems/3200-6000-mhz/3-3-ghz-4-2-ghz-rx...
I recommend you contact your local nxp sales representative
