How can I confirm that S32K144 currently in the VLPS mode?
PYGC
In VLPS mode, how to get the value of the SMC_PMSTAT register
Senlent
Hi@PYGG
My mistake, you may not able to read out the value of PMSTAT Register.
Two ways:
1.check the MCU power consumption is the must right way.
2.Enable CLKOUT on the PIN, measure BUS_CLK or CORE_CLK with an oscilloscope.
Senlent
Hi@PYGG
Two ways:
Senlent
PYGC
Thanks for your reply!
Core Clock is disabled in VLPS mode, CPU does not work, how to read PMSTAT?
and RM NOTE: When debug is enabled, the PMSTAT will not update to STOP or VLPS.
