Stack Overflow Failure Recovery of S32K3XX
2,828 次查看
raj12
I am injecting the stack overflow error of S32K3XX MCU, and after successfully injection of error DebugMon_Handler exception triggering.
I have a query Related to recovering methods. during testing observed only After power on reset MCU is able to recover from Stack Overflow exception.
Please let me know is there any other methods of recovery.
标记 (2)
2,802 次查看
danielmartynek
Hi @raj12,
Any reset can recover it.
The SP is set during the startup process.
Use the Power_Ip RTD driver to trigger a SW reset from the exception handler.
2,803 次查看
danielmartynek
Hi @raj12,
2,761 次查看
raj12
Hello @danielmartynek,
Thanks for your reply.
Now, I am now able to recover from stack overflow error after doing the functional reset.
Below is the pseudo code which currently, I am using for injection of stack overflow.
*DEMCR_reg = (1 << 24) | (1 << 16);
/* Get implemented values for num of comparators in DWT registers*/
numcomp = (DWT->CTRL & (0xF << 28)) >> 28;
DWT->NUMCOMP[0].COMP = (uint32_t)stackPointer - (1016 * sizeof(uint32_t));
DWT->NUMCOMP[0].MASK = 0;
DWT->NUMCOMP[0].FUNCTION = 0x7;
DWT->NUMCOMP[0].FUNCTION &= ~((1 << | /* Perform address comparison */
(1 << 7));
for (counter = 0, reg0 = 0; counter < 1016; counter++, reg0++)
__asm("PUSH {r0}");
Can you please let me know the other method to inject the stack over flow error.
because, I not want to use below variable there is some limitation on GHS compiler not allowing me to save the stack pointer (__asm("SP")) in register type variable.
register uint32_t* stackPointer __asm("sp");
Please let me know the other method for injecting the stack overflow/underflow error error it will be helpful for my development.
2,754 次查看
danielmartynek
Hi @raj12,
Call a recursive function (that calls itself) or create a large local variable.
%3CLINGO-SUB%20id%3D%22lingo-sub-1913896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32K3XX%E7%9A%84%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E6%95%85%E9%9A%9C%E6%81%A2%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1913896%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E6%B3%A8%E5%85%A5S32K3XX%20MCU%E7%9A%84%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E9%94%99%E8%AF%AF%EF%BC%8C%E6%88%90%E5%8A%9F%E6%B3%A8%E5%85%A5%E9%94%99%E8%AF%AF%E5%90%8EDebugMon_Handler%E5%BC%82%E5%B8%B8%E8%A7%A6%E5%8F%91%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E4%B8%8E%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%E7%9B%B8%E5%85%B3%E7%9A%84%E7%96%91%E9%97%AE%E3%80%82%E6%B5%8B%E8%AF%95%E6%9C%9F%E9%97%B4%E8%A7%82%E5%AF%9F%E5%88%B0%E4%BB%85%E5%9C%A8%E4%B8%8A%E7%94%B5%E5%A4%8D%E4%BD%8D%E5%90%8E%20MCU%20%E8%83%BD%E5%A4%9F%E4%BB%8E%20Stack%20Overflow%20%E5%BC%82%E5%B8%B8%E4%B8%AD%E6%81%A2%E5%A4%8D%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E6%98%AF%E5%90%A6%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E6%81%A2%E5%A4%8D%E6%96%B9%E6%B3%95%E3%80%82%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1918153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3XX%E7%9A%84%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E6%95%85%E9%9A%9C%E6%81%A2%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1918153%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225347%22%20target%3D%22_blank%22%3E%40raj12%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E8%B0%83%E7%94%A8%E9%80%92%E5%BD%92%E5%87%BD%E6%95%B0%EF%BC%88%E8%B0%83%E7%94%A8%E8%87%AA%E8%BA%AB%EF%BC%89%E6%88%96%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%A4%A7%E7%9A%84%E5%B1%80%E9%83%A8%E5%8F%98%E9%87%8F%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1917861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3XX%E7%9A%84%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E6%95%85%E9%9A%9C%E6%81%A2%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1917861%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%20%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E7%8E%B0%E5%9C%A8%EF%BC%8C%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%89%A7%E8%A1%8C%E5%8A%9F%E8%83%BD%E9%87%8D%E7%BD%AE%E5%90%8E%E4%BB%8E%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E9%94%99%E8%AF%AF%E4%B8%AD%E6%81%A2%E5%A4%8D%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E6%88%91%E7%9B%AE%E5%89%8D%E7%94%A8%E4%BA%8E%E6%B3%A8%E5%85%A5%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E7%9A%84%E4%BC%AA%E4%BB%A3%E7%A0%81%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E*DEMCR_reg%20%3D%20(1%20%26lt%3B%26lt%3B%2024)%20%7C%20(1%20%26lt%3B%26lt%3B%2016)%3B%3CBR%20%2F%3E%20%2F*%20%E8%8E%B7%E5%8F%96%20DWT%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E6%AF%94%E8%BE%83%E5%99%A8%E6%95%B0%E9%87%8F%E7%9A%84%E5%AE%9E%E7%8E%B0%E5%80%BC%20*%2F%3CBR%20%2F%3E%20numcomp%20%3D%20(DWT-%26gt%3BCTRL%20%26amp%3B%20(0xF%20%26lt%3B%26lt%3B%2028))%20%26gt%3B%26gt%3B%2028%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%20DWT-%26gt%3BNUMCOMP%5B0%5D.COMP%20%3D%20(uint32_t)stackPointer%20-%20(1016%20*%20sizeof(uint32_t))%3B%3CBR%20%2F%3E%20DWT-%26gt%3BNUMCOMP%5B0%5D.MASK%20%3D%200%3B%3CBR%20%2F%3E%20DWT-%26gt%3BNUMCOMP%5B0%5D.FUNCTION%20%3D%200x7%3B%3CBR%20%2F%3E%20DWT-%26gt%3BNUMCOMP%5B0%5D.FUNCTION%20%26amp%3B%3D%20~((1%20%26lt%3B%26lt%3B%20%7C%20%2F*%20%E6%89%A7%E8%A1%8C%E5%9C%B0%E5%9D%80%E6%AF%94%E8%BE%83%20*%2F%3CBR%20%2F%3E%20%EF%BC%881%20%26lt%3B%26lt%3B%207%EF%BC%89%EF%BC%89%EF%BC%9B%3CBR%20%2F%3E%E5%AF%B9%E4%BA%8E%EF%BC%88%E8%AE%A1%E6%95%B0%E5%99%A8%20%3D%200%EF%BC%8Creg0%20%3D%200%EF%BC%9B%E8%AE%A1%E6%95%B0%E5%99%A8%26lt%3B1016%EF%BC%9B%E8%AE%A1%E6%95%B0%E5%99%A8%2B%2B%EF%BC%8Creg0%2B%2B%EF%BC%89%3CBR%20%2F%3E%20%7B%3CBR%20%2F%3E%20__asm(%22PUSH%20%7Br0%7D%22)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3ECan%20you%20please%20let%20me%20know%20the%20other%20method%20to%20inject%20the%20stack%20over%20flow%20error.%3CBR%20%2F%3E%3CBR%20%2F%3Ebecause%2C%20I%20not%20want%20to%20use%20below%20variable%20there%20is%20some%20limitation%20on%20GHS%20compiler%20not%20allowing%20me%20to%20save%20the%20stack%20pointer%20(__%20asm(%22SP%22))%20%E4%BB%A5%E5%AF%84%E5%AD%98%E5%99%A8%E7%B1%BB%E5%9E%8B%E5%8F%98%E9%87%8F%E7%9A%84%E5%BD%A2%E5%BC%8F%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B3%A8%E5%86%8C%20uint32_t*%20stackPointer%20__asm(%22sp%22)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%AF%B7%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E6%B3%A8%E5%85%A5%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%2F%E4%B8%8B%E6%BA%A2%E9%94%99%E8%AF%AF%E7%9A%84%E5%8F%A6%E4%B8%80%E7%A7%8D%E6%96%B9%E6%B3%95%EF%BC%8C%E8%BF%99%E5%B0%86%E6%9C%89%E5%8A%A9%E4%BA%8E%E6%88%91%E7%9A%84%E5%BC%80%E5%8F%91%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1914873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AS32K3XX%E7%9A%84%E5%A0%86%E6%A0%88%E6%BA%A2%E5%87%BA%E6%95%85%E9%9A%9C%E6%81%A2%E5%A4%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1914873%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225347%22%20target%3D%22_blank%22%3E%40raj12%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3E%E4%BB%BB%E4%BD%95%E9%87%8D%E7%BD%AE%E9%83%BD%E5%8F%AF%E4%BB%A5%E6%81%A2%E5%A4%8D%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CP%3ESP%E6%98%AF%E5%9C%A8%E5%90%AF%E5%8A%A8%E8%BF%87%E7%A8%8B%E4%B8%AD%E8%AE%BE%E7%BD%AE%E7%9A%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%BF%E7%94%A8%20Power_Ip%20RTD%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%BB%8E%E5%BC%82%E5%B8%B8%E5%A4%84%E7%90%86%E7%A8%8B%E5%BA%8F%E8%A7%A6%E5%8F%91%20SW%20%E9%87%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3EDaniel%3C%2FP%3E%3C%2FLINGO-BODY%3E
