Some problem in the process of debugging
1,782 次查看
Hermit
Hello Team,
I have some trouble in debugging. When I try to import the project from others, and I have built it successfully.After configuring, I try to debug. But there is something wrong with it.It just shows that it can not find the source file "main.c" at specific path.And the path might be others, not mine.Therefore, I can not debug it.The screenshot is attached.
What should I do to configure it? I need your help. Thank you.
Best wishes,
Hermit.
1,762 次查看
Hermit
OK,thanks
1,765 次查看
Senlent
Hi@Hermit
please check your project included path, some invaild paths may causes such errors!
