Segger Jlink compatibility for Secure Debug/ Lifecycle updates of S32K324
anilsp31PA
We are using S32K3 and now want to install HSE FW. Can you confirm if Segger JLink supports secure Debug using Challenge/Response authentication. If not then what are the other options?
Anil
lukaszadrapa
Hi @anilsp31PA
This is a screenshot from Segger's web https://kb.segger.com/NXP_S32K3xx
So, it's not supported.
An option is either Pemicro or Lauterbach.
In case of Pemicro, please read following article:
https://www.pemicro.com/learningcenter/contents.cfm?content_id=82
In case of Lauterbach, there are some resources in HSE DemoApp (can be downloaded from the same place as HSE firmware).
You can take a look at scripts in HSE DemoApp at path like:
c:\NXP\HSE_DEMOAPP_S32K358_0_2_55_0\demo_security_installer\scripts\
See the files:
debug_App_ADKP.py
debug_authorization.cmm
adkp_key_input.txt
... or contact Lauterbach directly for help.
Lukas
anilsp31PA
In continuing further on same topic. The Demo App source and documentation contains steps for HSE_FW installation using Trace32 only. Is there a separate document and code for using PE-Micro debugger? I see documentation and .cmm scripts supported by Trace  32 only.
Anil
davidtosenovjan
HSE_DEMOAPP_S32K3XX only works with T32 but mentioned HSE examples are code based and may run with any debugger.
There are also examples S32K344_HSE_FW_INSTALL and S32K344_HSE_FW_UPDATE in HSE examples package:
https://www.nxp.com/webapp/Download?colCode=S32K3_HSE_DemoExamples
It is basically the same functionality ported to the code debugger independent
Quoting "c:\NXP\S32K3_HSE_DemoExamples_1_0_0\S32K3_HSE_DemoExamples\Readme.md":
'The purpose of this project is to provide different use-case scenarios and examples to showcase the capabilities of the HSE FW in different devices. This is a port of the well known HSE DEMO APP which requires T32 Lauterbach in order to work, in this case we are working with PEmicro and Design Studio as this two tools work well with eachother allowing debugging directly using Design Studio IDE.'
%3CLINGO-SUB%20id%3D%22lingo-sub-2354735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESegger%20Jlink%20compatibility%20for%20Secure%20Debug%2F%20Lifecycle%20updates%20of%20S32K324%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2354735%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EWe%20are%20using%20S32K3%20and%20now%20want%20to%20install%20HSE%20FW.%20Can%20you%20confirm%20if%20Segger%20JLink%20supports%20secure%20Debug%20using%20Challenge%2FResponse%20authentication.%20If%20not%20then%20what%20are%20the%20other%20options%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAnil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Segger%20Jlink%20compatibility%20for%20Secure%20Debug%2F%20Lifecycle%20updates%20of%20S32K324%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356681%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3EIn%20continuing%20further%20on%20same%20topic.%20The%20Demo%20App%20source%20and%20documentation%20contains%20steps%20for%20HSE_FW%20installation%20using%20Trace32%20only.%20Is%20there%20a%20separate%20document%20and%20code%20for%20using%20PE-Micro%20debugger%3F%20I%20see%20documentation%20and%20.cmm%20scripts%20supported%20by%20Trace%26nbsp%3B%2032%20only.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EThanks%2C%3C%2FP%3E%3CP%3EAnil%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Segger%20Jlink%20compatibility%20for%20Secure%20Debug%2F%20Lifecycle%20updates%20of%20S32K324%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229232%22%20target%3D%22_blank%22%3E%40anilsp31PA%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThis%20is%20a%20screenshot%20from%20Segger's%20web%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fkb.segger.com%2FNXP_S32K3xx%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fkb.segger.com%2FNXP_S32K3xx%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22lukaszadrapa_0-1776943251999.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1776943251999.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22lukaszadrapa_0-1776943251999.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F383328iE90F018EDB0574C8%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22lukaszadrapa_0-1776943251999.png%22%20alt%3D%22lukaszadrapa_0-1776943251999.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3ESo%2C%20it's%20not%20supported.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EAn%20option%20is%20either%20Pemicro%20or%20Lauterbach.%26nbsp%3B%3C%2FP%3E%0A%3CP%3EIn%20case%20of%20Pemicro%2C%20please%20read%20following%20article%3A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Flearningcenter%2Fcontents.cfm%3Fcontent_id%3D82%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.pemicro.com%2Flearningcenter%2Fcontents.cfm%3Fcontent_id%3D82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIn%20case%20of%20Lauterbach%2C%20there%20are%20some%20resources%20in%20HSE%20DemoApp%20(can%20be%20downloaded%20from%20the%20same%20place%20as%20HSE%20firmware).%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%3EYou%20can%20take%20a%20look%20at%20scripts%20in%20HSE%20DemoApp%20at%20path%20like%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Ec%3A%5CNXP%5CHSE_DEMOAPP_S32K358_0_2_55_0%5Cdemo_security_installer%5Cscripts%5C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ESee%20the%20files%3A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Edebug_App_ADKP.py%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Edebug_authorization.cmm%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3Eadkp_key_input.txt%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E...%20or%20contact%20Lauterbach%20directly%20for%20help.%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ERegards%2C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3ELukas%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2359010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Segger%20Jlink%20compatibility%20for%20Secure%20Debug%2F%20Lifecycle%20updates%20of%20S32K324%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2359010%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHSE_DEMOAPP_S32K3XX%20only%20works%20with%20T32%20but%20mentioned%20HSE%20examples%20are%20code%20based%20and%20may%20run%20with%20any%20debugger.%3C%2FP%3E%0A%3CP%3EThere%20are%20also%20examples%20S32K344_HSE_FW_INSTALL%20and%20S32K344_HSE_FW_UPDATE%20in%20HSE%20examples%20package%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HSE_DemoExamples%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fwebapp%2FDownload%3FcolCode%3DS32K3_HSE_DemoExamples%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIt%20is%20basically%20the%20same%20functionality%20ported%20to%20the%20code%20debugger%20independent%3C%2FP%3E%0A%3CP%3EQuoting%20%22c%3A%5CNXP%5CS32K3_HSE_DemoExamples_1_0_0%5CS32K3_HSE_DemoExamples%5CReadme.md%22%3A%3CBR%20%2F%3E'The%20purpose%20of%20this%20project%20is%20to%20provide%20different%20use-case%20scenarios%20and%20examples%20to%20showcase%20the%20capabilities%20of%20the%20HSE%20FW%20in%20different%20devices.%20This%20is%20a%20port%20of%20the%20well%20known%20HSE%20DEMO%20APP%20which%20requires%20T32%20Lauterbach%20in%20order%20to%20work%2C%20in%20this%20case%20we%20are%20working%20with%20PEmicro%20and%20Design%20Studio%20as%20this%20two%20tools%20work%20well%20with%20eachother%20allowing%20debugging%20directly%20using%20Design%20Studio%20IDE.'%3C%2FP%3E%3C%2FLINGO-BODY%3E
