SJA1105 Configuration
1,132件の閲覧回数
jianghao
Using the GMAC interface of S32K344 to connect with SJA1105, according to the manual, after enabling the auto-negotiation function on the RGMII port, and then sending a complete "static configuration table" to SJA1105 via the SPI interface, it is possible to adaptively obtain the actual 2.5/25/125 MHz clocks required by the RGMII port. Thus, it is possible to adaptively determine whether manual dynamic clock frequency division is needed to obtain 125 MHz/25 MHz/2.5 MHz clocks?image.png
2 返答(返信)
1,028件の閲覧回数
PavelL
Hello @jianghao ,
I think there is a small terminology mix-up here regarding Auto‑Negotiation vs. RGMII interface clocking.
Auto‑Negotiation is not a function of RGMII. RGMII is just the parallel MAC↔MAC / MAC↔PHY interface (data + source‑synchronous clocks). The link partner “Auto‑Negotiation” (speed/duplex capability exchange) happens on the PHY line side (e.g., 100BASE‑TX / 1000BASE‑T / 100BASE‑T1 etc.), not on the RGMII pins. In other words, S32K344 EMAC and SJA1105 do not “negotiate” speed over RGMII in the way SGMII/PCS-based links can.
The SJA1105 is an SPI-managed switch; you must load a static configuration after reset/power-up, and this configuration defines per-port interface mode and operational parameters. The typical software model is “configure and keep,” with only limited dynamic updates at runtime.
If your S32K344 EMAC ↔ SJA1105 connection is a MAC‑to‑MAC (PHY-less) RGMII link, the usual approach is to treat it as a fixed link and keep it at a chosen speed (S32K344 EMAC doesn't support 1Gbps).
Pavel
999件の閲覧回数
jianghao
@PavelL Thanks, I understand.
%3CLINGO-SUB%20id%3D%22lingo-sub-2353659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESJA1105%E6%A7%8B%E6%88%90%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2353659%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81S32K344%E3%81%AEGMAC%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SJA1105%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%80%81RGMII%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%88%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E6%A9%9F%E8%83%BD%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81SPI%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E7%B5%8C%E7%94%B1%E3%81%A7%E5%AE%8C%E5%85%A8%E3%81%AA%E3%80%8C%E9%9D%99%E7%9A%84%E6%A7%8B%E6%88%90%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%80%8D%E3%82%92SJA1105%E3%81%AB%E9%80%81%E4%BF%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%80%81RGMII%E3%83%9D%E3%83%BC%E3%83%88%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%A8%E3%81%99%E3%82%8B%E5%AE%9F%E9%9A%9B%E3%81%AE2.5%2F25%2F125MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E9%81%A9%E5%BF%9C%E7%9A%84%E3%81%AB%E5%8F%96%E5%BE%97%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E3%81%AE%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81125MHz%2F25MHz%2F2.5MHz%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%8F%96%E5%BE%97%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E3%80%81%E6%89%8B%E5%8B%95%E3%81%AB%E3%82%88%E3%82%8B%E5%8B%95%E7%9A%84%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E5%91%A8%E6%B3%A2%E6%95%B0%E5%88%86%E5%89%B2%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E3%82%92%E9%81%A9%E5%BF%9C%E7%9A%84%E3%81%AB%E5%88%A4%E6%96%AD%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%20%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22image.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F382951iDCAD666FFCA300D1%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22image.png%22%20alt%3D%22image.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SJA1105%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355784%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233505%22%20target%3D%22_blank%22%3E%40PavelL%3C%2FA%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%81%E7%90%86%E8%A7%A3%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2355262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20SJA1105%20Configuration%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355262%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F256141%22%20target%3D%22_blank%22%3E%40jianghao%20%E3%81%95%E3%82%93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%AA%E3%83%BC%E3%83%88%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%81%A8RGMII%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%AE%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%AB%E9%96%A2%E3%81%97%E3%81%A6%E3%80%81%E7%94%A8%E8%AA%9E%E3%81%AE%E6%B7%B7%E5%90%8C%E3%81%8C%E5%B0%91%E3%81%97%E3%81%82%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%AA%E5%8B%95%E4%BA%A4%E6%B8%89%E3%81%AFRGMII%E3%81%AE%E6%A9%9F%E8%83%BD%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82RGMII%E3%81%AF%E3%80%81%E4%B8%A6%E5%88%97MAC%E2%86%94MAC%20%2F%20MAC%E2%86%94PHY%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%EF%BC%88%E3%83%87%E3%83%BC%E3%82%BF%EF%BC%8B%E3%82%BD%E3%83%BC%E3%82%B9%E5%90%8C%E6%9C%9F%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%EF%BC%89%E3%81%AB%E9%81%8E%E3%81%8E%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%AA%E3%83%B3%E3%82%AF%E3%83%91%E3%83%BC%E3%83%88%E3%83%8A%E3%83%BC%E3%81%AE%E3%80%8C%E3%82%AA%E3%83%BC%E3%83%88%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%80%8D%EF%BC%88%E9%80%9F%E5%BA%A6%2F%E3%83%87%E3%83%A5%E3%83%97%E3%83%AC%E3%83%83%E3%82%AF%E3%82%B9%E6%A9%9F%E8%83%BD%E3%81%AE%E4%BA%A4%E6%8F%9B%EF%BC%89%E3%81%AF%E3%80%81RGMII%E3%83%94%E3%83%B3%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81PHY%E3%83%A9%E3%82%A4%E3%83%B3%E5%81%B4%EF%BC%88%E4%BE%8B%EF%BC%9A100BASE-TX%20%2F%201000BASE-T%20%2F%20100BASE-T1%E3%81%AA%E3%81%A9%EF%BC%89%E3%81%A7%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81S32K344%20EMAC%E3%81%A8SJA1105%E3%81%AF%E3%80%81SGMII%2FPCS%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AE%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABRGMII%E4%B8%8A%E3%81%A7%E9%80%9F%E5%BA%A6%E3%82%92%E3%80%8C%E3%83%8D%E3%82%B4%E3%82%B7%E3%82%A8%E3%83%BC%E3%83%88%E3%80%8D%E3%81%99%E3%82%8B%E3%82%8F%E3%81%91%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3ESJA1105%E3%81%AFSPI%E7%AE%A1%E7%90%86%E5%9E%8B%E3%82%B9%E3%82%A4%E3%83%83%E3%83%81%E3%81%A7%E3%81%99%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%2F%E9%9B%BB%E6%BA%90%E6%8A%95%E5%85%A5%E5%BE%8C%E3%81%AB%E9%9D%99%E7%9A%84%E8%A8%AD%E5%AE%9A%E3%82%92%E3%83%AD%E3%83%BC%E3%83%89%E3%81%99%E3%82%8B%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%83%9D%E3%83%BC%E3%83%88%E3%81%94%E3%81%A8%E3%81%AE%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A8%E5%8B%95%E4%BD%9C%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AA%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%83%A2%E3%83%87%E3%83%AB%E3%81%AF%E3%80%8C%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%A6%E4%BF%9D%E6%8C%81%E3%81%99%E3%82%8B%E3%80%8D%E3%82%82%E3%81%AE%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81%E5%AE%9F%E8%A1%8C%E6%99%82%E3%81%AE%E5%8B%95%E7%9A%84%E3%81%AA%E6%9B%B4%E6%96%B0%E3%81%AF%E9%99%90%E5%AE%9A%E7%9A%84%E3%81%A7%E3%81%82%E3%82%8B%E3%80%82%3C%2FP%3E%0A%3CP%3ES32K344%20EMAC%20%E2%86%94%20SJA1105%20%E6%8E%A5%E7%B6%9A%E3%81%8C%20MAC-to-MAC%20(PHY%20%E3%83%AC%E3%82%B9)%20RGMII%20%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A7%E3%81%82%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E9%80%9A%E5%B8%B8%E3%81%AE%E3%82%A2%E3%83%97%E3%83%AD%E3%83%BC%E3%83%81%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%82%92%E5%9B%BA%E5%AE%9A%E3%83%AA%E3%83%B3%E3%82%AF%E3%81%A8%E3%81%97%E3%81%A6%E6%89%B1%E3%81%84%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%E9%80%9F%E5%BA%A6%E3%82%92%E7%B6%AD%E6%8C%81%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%20(S32K344%20EMAC%20%E3%81%AF%201Gbps%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
