SBC Watch Dog refresh time
4,064 次查看
Linn1
MC33FS4508 how to configure watchdog 32ms refresh time parameters, how to configure to achieve the purpose of receiving CAN messages within 200ms after power on
3,960 次查看
guoweisun
after you set the WD period time,did you correctly feed the WD? What's the error count?
6 回复数
3,986 次查看
Linn1
Set the WD_WINDOW register WD_WINDOW_3:0 as '1010' , But it is still reset, is there any other setting to make it work normally. It is normal if you use defult setting to 512 ms
3,981 次查看
guoweisun
why does it reset after your set this register?
4,048 次查看
guoweisun
You can set the WD_WINDOW register WD_WINDOW_3:0 as '1010' to get the 32ms refresh time.
3,969 次查看
Linn1
Watchdog timer, set to refresh the WD in 3/4 of the period (open window). It means that the MCU is reset by the SBC .
3,961 次查看
guoweisun
3,949 次查看
Linn1
We have solved, need to set correct WD period time. Thanks !
