S32k388 ethercat config
ソリューションへジャンプ
2,367件の閲覧回数
vinmotion
Hello engineers, im new to nxp and ethercat. I wonder if anyone has experience using ethercat with nxp ; how should i config the project or pin to use ethercat with KSZ9131...
Thanks a lot
2,318件の閲覧回数
PavelL
Hello @vinmotion ,
It seems that S32K388 might not be the best choice for EtherCAT, because EtherCAT typically requires a dedicated EtherCAT Slave Controller (ESC) - this is a hardware block that handles on-the-fly frame processing and distributed clocks. S32K388 does not have an integrated ESC, so implementing EtherCAT would require an external controller or a software stack with strict timing constraints.
EtherCAT is generally a domain of the i.MX family, and NXP provides solutions with integrated ESC. For example, the i.MX RT1180 includes a built-in EtherCAT two-port slave controller, making it much easier to implement EtherCAT without additional hardware.
Please check this application note related to i.MX RT1180 and EtherCAT:
https://www.nxp.com/docs/en/application-note/AN14155.pdf
Pavel
3 返答(返信)
2,319件の閲覧回数
PavelL
Hello @vinmotion ,
Pavel
2,293件の閲覧回数
vinmotion
Thank you Sir, so i cannot use above design for s32k388 work as ethercat master to control ethercat motor ..?
2,273件の閲覧回数
PavelL
Hello @vinmotion ,
I reviewed EtherCAT once again, and even though S32K388 does not have integrated EtherCAT Slave Controller (ESC), it features two GMAC interfaces with TSN/AVB support and sufficient processing power to run an EtherCAT software stack.
Please verify S32K388 & EtherCAT compatibility with your EtherCAT stack provider to ensure proper integration and timing requirements.
Pavel
%3CLINGO-SUB%20id%3D%22lingo-sub-2193972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k388%20%E3%82%A4%E3%83%BC%E3%82%B5%E3%82%AD%E3%83%A3%E3%83%83%E3%83%88%E8%A8%AD%E5%AE%9A%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193972%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%E3%82%A8%E3%83%B3%E3%82%B8%E3%83%8B%E3%82%A2%E3%81%AE%E7%9A%86%E3%81%95%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%20NXP%20%E3%81%A8%20EtherCAT%20%E3%81%AE%E5%88%9D%E5%BF%83%E8%80%85%E3%81%A7%E3%81%99%E3%80%82nxp%20%E3%81%A7%20ethercat%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%E7%B5%8C%E9%A8%93%E3%81%AE%E3%81%82%E3%82%8B%E6%96%B9%E3%81%AF%E3%81%84%E3%82%89%E3%81%A3%E3%81%97%E3%82%83%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%E3%80%82KSZ9131%20%E3%81%A7%20ethercat%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%BE%E3%81%9F%E3%81%AF%E3%83%94%E3%83%B3%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A9%E3%81%86%E3%82%82%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22nxpETHERCAT.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22nxpETHERCAT.png%22%20style%3D%22width%3A%20536px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F362814i049BB04BA0E3E7FD%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22nxpETHERCAT.png%22%20alt%3D%22nxpETHERCAT.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k388%20ethercat%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254753%22%20target%3D%22_blank%22%3E%40vinmotion%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3E%E3%82%82%E3%81%86%E4%B8%80%E5%BA%A6%20EtherCAT%20%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%20%3CSTRONG%3ES32K388%20%E3%81%AB%E3%81%AF%20EtherCAT%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(ESC)%20%E3%81%8C%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84%3C%2FSTRONG%3E%E3%81%AB%E3%82%82%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81%20%3CSTRONG%3ETSN%2FAVB%20%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%202%20%E3%81%A4%E3%81%AE%20GMAC%20%E3%82%A4%E3%83%B3%E3%82%BF%E3%83%BC%E3%83%95%E3%82%A7%E3%83%BC%E3%82%B9%E3%81%A8%3C%2FSTRONG%3E%E3%80%81EtherCAT%20%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%E3%81%AE%E3%81%AB%E5%8D%81%E5%88%86%E3%81%AA%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E8%83%BD%E5%8A%9B%E3%81%8C%E5%82%99%E3%82%8F%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%81%A9%E5%88%87%E3%81%AA%E7%B5%B1%E5%90%88%E3%81%A8%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E8%A6%81%E4%BB%B6%E3%82%92%E7%A2%BA%E4%BF%9D%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81EtherCAT%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%20%E3%83%97%E3%83%AD%E3%83%90%E3%82%A4%E3%83%80%E3%83%BC%E3%81%AB%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%A6%3CSTRONG%3ES32K388%20%E3%81%A8%20EtherCAT%20%E3%81%AE%E4%BA%92%E6%8F%9B%E6%80%A7%3C%2FSTRONG%3E%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k388%20ethercat%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195366%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%A7%E3%81%AF%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%87%E3%82%B6%E3%82%A4%E3%83%B3%E3%82%92%20s32k388%20%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%80%81EtherCAT%20%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%80%81EtherCAT%20%E3%83%A2%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%92%E5%88%B6%E5%BE%A1%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%84%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k388%20ethercat%20config%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194958%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254753%22%20target%3D%22_blank%22%3E%40vinmotion%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%0A%3CP%3EEtherCAT%20%E3%81%A7%E3%81%AF%E9%80%9A%E5%B8%B8%E3%80%81%E5%B0%82%E7%94%A8%E3%81%AE%20EtherCAT%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%20(ESC)%20%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81S32K388%20%E3%81%AF%20EtherCAT%20%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E6%9C%80%E9%81%A9%E3%81%AA%E9%81%B8%E6%8A%9E%E8%82%A2%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%E3%80%81%E3%82%AA%E3%83%B3%E3%82%B6%E3%83%95%E3%83%A9%E3%82%A4%E3%81%AE%E3%83%95%E3%83%AC%E3%83%BC%E3%83%A0%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B7%E3%83%B3%E3%82%B0%E3%81%A8%E5%88%86%E6%95%A3%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%82%92%E5%87%A6%E7%90%86%E3%81%99%E3%82%8B%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%83%96%E3%83%AD%E3%83%83%E3%82%AF%E3%81%A7%E3%81%99%E3%80%82S32K388%20%E3%81%AB%E3%81%AF%20ESC%20%E3%81%8C%E7%B5%B1%E5%90%88%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%AA%E3%81%84SO%E3%80%81EtherCAT%20%E3%82%92%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%BE%E3%81%9F%E3%81%AF%E5%8E%B3%E3%81%97%E3%81%84%E3%82%BF%E3%82%A4%E3%83%9F%E3%83%B3%E3%82%B0%E5%88%B6%E7%B4%84%E3%81%AE%E3%81%82%E3%82%8B%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%20%E3%82%B9%E3%82%BF%E3%83%83%E3%82%AF%E3%81%8C%E5%BF%85%E8%A6%81%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EEtherCAT%20%E3%81%AF%E4%B8%80%E8%88%AC%E7%9A%84%E3%81%AB%20i.MX%20%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%89%E3%83%A1%E3%82%A4%E3%83%B3%E3%81%A7%E3%81%82%E3%82%8A%E3%80%81NXP%20%E3%81%AF%20ESC%20%E3%82%92%E7%B5%B1%E5%90%88%E3%81%97%E3%81%9F%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%9F%E3%81%A8%E3%81%88%E3%81%B0%E3%80%81%20%3CSTRONG%3Ei.MX%20RT1180%3C%2FSTRONG%3E%E3%81%AB%E3%81%AF%20EtherCAT%202%20%E3%83%9D%E3%83%BC%E3%83%88%20%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%20%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%8C%E7%B5%84%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E8%BF%BD%E5%8A%A0%E3%81%AE%E3%83%8F%E3%83%BC%E3%83%89%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AA%E3%81%97%E3%81%A7%20EtherCAT%20%E3%82%92%E7%B0%A1%E5%8D%98%E3%81%AB%E5%AE%9F%E8%A3%85%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3Ei.MX%20RT1180%E3%81%A8EtherCAT%E3%81%AB%E9%96%A2%E9%80%A3%E3%81%99%E3%82%8B%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%8E%E3%83%BC%E3%83%88%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14155.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN14155.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%91%E3%83%99%E3%83%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
