S32K358 multi core with same SDK
已解决
跳至解决方案
3,020 次查看
nirmal_masilamani
Contributor V
Hello Team,
We are using S32K358 with Multi core.
Since we need to build separate project for each core, is it possible to use single SDK, for multi core?
标记 (2)
1 解答
2,875 次查看
danielmartynek
Hi @nirmal_masilamani,
Here is a simple example:
https://community.nxp.com/t5/S32K-Knowledge-Base/S32K358-Multicore-Start-CM7-2-from-CM7-0/ta-p/19238...
There isn’t a dedicated document for this; the reference manual is the primary source of information.
BR, Daniel
在原帖中查看解决方案
6 回复数
2,987 次查看
danielmartynek
What do you mean by single SDK?
Do you use S32DS IDE to configure the drivers or do you use Tresos?
2,985 次查看
nirmal_masilamani
Contributor V
Using S32DS IDE.
What do you mean by single SDK? - > In S32DS, if i create an application project for S32K548, 2 separate projects created for each core. Each project has its own config .mex file, RTD files and everything's.
My doubt is, since both cores use same SDK, can we use single SDK?
Instead of separate SDK files.
标记 (2)
2,942 次查看
danielmartynek
What would be the purpose of it?
Each core project in the S32DS IDE (S32K3xx RTD) has its own configuration tool and corresponding .mex file. This is necessary because typically, each core is responsible for different tasks and therefore uses different peripherals.
For example:
If CM7_0 uses the ADC, its RTD folder will include the source files for the ADC driver.
If CM7_2 uses the UART, its RTD folder will contain the UART driver source files.
Even though some RTD source files may exist in both projects, only the modules and functions actually used by each core are compiled and linked into its final image.
2,913 次查看
nirmal_masilamani
Contributor V
Hello @danielmartynek ,
Thank for your reply,
Is there any documents or example project for S32K38, on which core is started first and how to start other core's?
标记 (2)
2,876 次查看
danielmartynek
BR, Daniel
2,839 次查看
nirmal_masilamani
Contributor V
Thank for the information.
标记 (2)
%3CLINGO-SUB%20id%3D%22lingo-sub-2192478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E9%87%87%E7%94%A8%E7%9B%B8%E5%90%8C%20SDK%20%E7%9A%84%20S32K358%20%E5%A4%9A%E6%A0%B8%E5%A4%84%E7%90%86%E5%99%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192478%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E5%9B%A2%E9%98%9F%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%AC%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%A4%9A%E6%A0%B8%20S32K358%E3%80%82%3C%2FP%3E%3CP%3E%E6%97%A2%E7%84%B6%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E4%B8%BA%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E7%89%88%E6%9C%AC%E5%8D%95%E7%8B%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%EF%BC%8C%E6%98%AF%E5%90%A6%E5%8F%AF%E4%BB%A5%E4%B8%BA%E5%A4%9A%E6%A0%B8%E4%BD%BF%E7%94%A8%E5%8D%95%E4%B8%AA%20SDK%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2195538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2195538%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194926%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233316%22%20target%3D%22_blank%22%3E%40nirmal_masilamani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E4%B8%80%E4%B8%AA%E7%AE%80%E5%8D%95%E7%9A%84%E4%BE%8B%E5%AD%90%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K358-Multicore-Start-CM7-2-from-CM7-0%2Fta-p%2F1923889%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K358-Multicore-Start-CM7-2-from-CM7-0%2Fta-p%2F1923889%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%B2%A1%E6%9C%89%E4%B8%93%E7%94%A8%E7%9A%84%E6%96%87%E6%A1%A3%EF%BC%9B%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E6%98%AF%E4%B8%BB%E8%A6%81%E7%9A%84%E4%BF%A1%E6%81%AF%E6%9D%A5%E6%BA%90%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%EF%BC%8C%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2194141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2194141%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F160001%22%20target%3D%22_blank%22%3E%40danielmartynek%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E7%AD%94%E5%A4%8D%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E4%BB%BB%E4%BD%95%E6%96%87%E4%BB%B6%E6%88%96%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E8%AF%B4%E6%98%8E%20S32K38%20%E9%A6%96%E5%85%88%E5%90%AF%E5%8A%A8%E5%93%AA%E4%B8%AA%E5%86%85%E6%A0%B8%EF%BC%8C%E4%BB%A5%E5%8F%8A%E5%A6%82%E4%BD%95%E5%90%AF%E5%8A%A8%E5%85%B6%E4%BB%96%E5%86%85%E6%A0%B8%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2193480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2193480%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233316%22%20target%3D%22_blank%22%3E%40nirmal_masilamani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%A0%B7%E5%81%9A%E7%9A%84%E7%9B%AE%E7%9A%84%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3ES32DS%20IDE%EF%BC%88S32K3xx%20RTD%EF%BC%89%E4%B8%AD%E7%9A%84%E6%AF%8F%E4%B8%AA%E6%A0%B8%E5%BF%83%E9%A1%B9%E7%9B%AE%E9%83%BD%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E9%85%8D%E7%BD%AE%E5%B7%A5%E5%85%B7%E5%92%8C%E7%9B%B8%E5%BA%94%E7%9A%84%20.mex%E9%94%89%E5%88%80%E8%BF%99%E6%98%AF%E5%BF%85%E8%A6%81%E7%9A%84%EF%BC%8C%E5%9B%A0%E4%B8%BA%E9%80%9A%E5%B8%B8%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8C%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E8%B4%9F%E8%B4%A3%E4%B8%8D%E5%90%8C%E7%9A%84%E4%BB%BB%E5%8A%A1%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%BD%BF%E7%94%A8%E4%B8%8D%E5%90%8C%E7%9A%84%E5%A4%96%E8%AE%BE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%9A%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%20CM7_0%20%E4%BD%BF%E7%94%A8%20ADC%EF%BC%8C%E5%85%B6%20RTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%E5%B0%86%E5%8C%85%E5%90%AB%20ADC%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E6%BA%90%E6%96%87%E4%BB%B6%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%20CM7_2%20%E4%BD%BF%E7%94%A8%20UART%EF%BC%8C%E5%85%B6%20RTD%20%E6%96%87%E4%BB%B6%E5%A4%B9%E5%B0%86%E5%8C%85%E5%90%AB%20UART%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E6%BA%90%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B0%BD%E7%AE%A1%E4%B8%A4%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%E9%83%BD%E5%8F%AF%E8%83%BD%E5%AD%98%E5%9C%A8%E4%B8%80%E4%BA%9B%20RTD%20%E6%BA%90%E6%96%87%E4%BB%B6%EF%BC%8C%E4%BD%86%E5%8F%AA%E6%9C%89%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E5%AE%9E%E9%99%85%E4%BD%BF%E7%94%A8%E7%9A%84%E6%A8%A1%E5%9D%97%E5%92%8C%E5%87%BD%E6%95%B0%E6%89%8D%E4%BC%9A%E8%A2%AB%E7%BC%96%E8%AF%91%E5%B9%B6%E9%93%BE%E6%8E%A5%E5%88%B0%E6%9C%80%E7%BB%88%E6%98%A0%E5%83%8F%E4%B8%AD%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E4%B8%B9%E5%B0%BC%E5%B0%94%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192533%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%20S32DS%20IDE%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%82%A8%E8%AF%B4%E7%9A%84%E5%8D%95%E4%B8%80%20SDK%20%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F-%26gt%3B%20%E5%9C%A8%20S32DS%20%E4%B8%AD%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E4%B8%BA%20S32K548%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E9%A1%B9%E7%9B%AE%EF%BC%8C%E5%B0%B1%E4%BC%9A%E4%B8%BA%E6%AF%8F%E4%B8%AA%E5%86%85%E6%A0%B8%E5%88%9B%E5%BB%BA%202%20%E4%B8%AA%E5%8D%95%E7%8B%AC%E7%9A%84%E9%A1%B9%E7%9B%AE%E3%80%82%E6%AF%8F%E4%B8%AA%E9%A1%B9%E7%9B%AE%E9%83%BD%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E9%85%8D%E7%BD%AE%20.mex%E6%96%87%E4%BB%B6%E3%80%81RTD%20%E6%96%87%E4%BB%B6%E5%92%8C%E5%85%B6%E4%BB%96%E6%89%80%E6%9C%89%E6%96%87%E4%BB%B6%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E7%96%91%E9%97%AE%E6%98%AF%EF%BC%8C%E6%97%A2%E7%84%B6%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20SDK%EF%BC%8C%E9%82%A3%E4%B9%88%E6%88%91%E4%BB%AC%E8%83%BD%E4%BD%BF%E7%94%A8%E5%8D%95%E4%B8%80%E7%9A%84%20SDK%20%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%80%8C%E4%B8%8D%E6%98%AF%E5%8D%95%E7%8B%AC%E7%9A%84%20SDK%20%E6%96%87%E4%BB%B6%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2192527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32K358%20multi%20core%20with%20same%20SDK%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2192527%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F233316%22%20target%3D%22_blank%22%3E%40nirmal_masilamani%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%AF%B4%E7%9A%84%E5%8D%95%E4%B8%80%20SDK%20%E6%98%AF%E4%BB%80%E4%B9%88%E6%84%8F%E6%80%9D%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E6%98%AF%E4%BD%BF%E7%94%A8%20S32DS%20IDE%20%E9%85%8D%E7%BD%AE%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E8%BF%98%E6%98%AF%E4%BD%BF%E7%94%A8%20Tresos%EF%BC%9F%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
