S32k344 legacy fifo with DMA and without interrupt
361 次查看
sbidkar
int main(void)
uint32_t * pu32CANFIFO1_RegAddress = (uint32_t *)(IP_CAN_0_BASE + 0x80);
uint32_t * pu32FIFO_Data = &FlaxCAN_u16DMA_FifoBuffers[0];
//FLEXCAN_Type * const psFlexCANBase = IP_CAN_0;
/* Write your code here */
// 1. Init Clock, Resource Manager, Pin mux (Siul2_Port_Ip_Init), etc.
Clock_Ip_Init(&Clock_Ip_aClockConfig[0]);
Siul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS_PortContainer_0_BOARD_InitPeripherals, g_pin_mux_InitConfigArr_PortContainer_0_BOARD_InitPeripherals);
Dma_Ip_Init(&Dma_Ip_Sa_xDmaInitPB);
Rm_Init(&Rm_Config);
// 2. Install and enable DMA interrupt and FlexCAN interrupt
// IntCtrl_Ip_InstallHandler(DMATCD0_IRQn, Dma0_Ch0_IRQHandler, NULL_PTR);
// IntCtrl_Ip_EnableIrq(DMATCD0_IRQn);
// IntCtrl_Ip_InstallHandler(FlexCAN0_1_IRQn, CAN0_ORED_0_31_MB_IRQHandler,NULL_PTR);
// IntCtrl_Ip_EnableIrq(FlexCAN0_1_IRQn);
// 3. Init DMA
//Dma_Ip_Init(&Dma_Ip_xDmaInitPB);
Dma_Ip_LogicChannelTransferListType asDmaCh1TransferList[2] =
{DMA_IP_CH_SET_SOURCE_ADDRESS, (uint32_t)pu32CANFIFO1_RegAddress},
{DMA_IP_CH_SET_DESTINATION_ADDRESS, (uint32_t)pu32FIFO_Data}// (uint32_t)P1OS_Cpu_ConvertLocalAddress(&pu32FIFO_Data[0])}
Dma_Ip_SetLogicChannelTransferList(SA_DMA_LOGIC_CH_0, asDmaCh1TransferList, 2);
Dma_Ip_SetLogicChannelCommand(SA_DMA_LOGIC_CH_0 , DMA_IP_CH_SET_HARDWARE_REQUEST);
// 4. Init FlexCAN0
FlexCAN_Ip_Init(INST_FLEXCAN_0, &FlexCAN_State0, &FlexCAN_Config0);
// 5. Configure Rx FIFO (legacy)
FlexCAN_Ip_SetRxMaskType_Privileged(INST_FLEXCAN_0,FLEXCAN_RX_MASK_INDIVIDUAL);
FlexCAN_Ip_ConfigRxFifo_Privileged(INST_FLEXCAN_0,FLEXCAN_RX_FIFO_ID_FORMAT_A , &CAN0_FIFO_IdFilterTable[0]);
// Configure individual mask for first filter (accept range 0x50–0x5F)
FlexCAN_Ip_SetRxIndividualMask(INST_FLEXCAN_0, 0, 0x7F0<<19); // mask for first ID in Filter table 0x50 to 0x5F
// Optional: MB-based receive setup
// FlexCAN_Ip_ConfigRxMb(INST_FLEXCAN_0, RX_MB_IDX, &rx_info, 0x20u); // uncomment for MB
// 6. Start FlexCAN controller
FlexCAN_Ip_SetStartMode(INST_FLEXCAN_0);
// 7. Send an initial dummy TX message via MB
FlexCAN_Ip_Send(INST_FLEXCAN_0, TX_MB_IDX, &tx_info, TX_MSG_ID, dummyData);
// Read Rx FIFO (initial read)---->DMA has transferred data from RxFIFO to rxFifoData
FlexCAN_Ip_RxFifo(INST_FLEXCAN_0, &rxFifoData);
// Read Rx MB (initial read)
// FlexCAN_Ip_Receive(INST_FLEXCAN_0, RX_MB_IDX, &rxData, FALSE); // uncomment for MB receive
while (1) {
the code is working with interrupt but not without interrupt
source and destination address are configured
please suggest better solution
311 次查看
PetrS
RTD driver is written in that way.  FlexCAN_Ip_RxFifo configs DMA channel to perform single read from RXFIFO and clear request. DMA interrupt should be enabled, which calls DMA_Can_Callback0 (for CAN0 instance)->FlexCAN_CompleteRxMessageFifoData, that check for DMA error, do some bit manipulation on data buffer and finally calls FlexCAN callback to notify user about the result. In this callback you can call FlexCAN_Ip_RxFifo to reenable DMA channel again.
If you wont to have different behavior, you can modify driver, which is not recommended, or do own implementation.
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-2204123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k344%20%E4%BC%A0%E7%BB%9F%20fifo%EF%BC%8C%E5%B8%A6%20DMA%EF%BC%8C%E4%B8%8D%E5%B8%A6%E4%B8%AD%E6%96%AD%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204123%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eint%20main(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Euint32_t%20*%20pu32CANFIFO1_RegAddress%20%3D%20(uint32_t%20*)(IP_CAN_0_BASE%20%2B%200x80)%EF%BC%9B%3C%2FP%3E%3CP%3Euint32_t%20*%20pu32FIFO_Data%20%3D%26amp%3BFlaxCAN_u16DMA_FifoBuffers%5B0%5D%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2FFLEXCAN_Type%20*%20const%20psFlexCANBase%20%3D%20IP_CAN_0%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%9C%A8%E6%AD%A4%E5%A4%84%E7%BC%96%E5%86%99%E4%BB%A3%E7%A0%81%20*%2F%3C%2FP%3E%3CP%3E%2F%2F%201.%20%E5%88%9D%E5%A7%8B%E5%8C%96%E6%97%B6%E9%92%9F%E3%80%81%E8%B5%84%E6%BA%90%E7%AE%A1%E7%90%86%E5%99%A8%E3%80%81%E5%BC%95%E8%84%9A%E5%A4%8D%E7%94%A8%E5%99%A8%EF%BC%88Siul2_Port_Ip_Init%EF%BC%89%E7%AD%89%E3%80%82%3C%2FP%3E%3CP%3EClock_Ip_Init(%26amp%3BClock_Ip_aClockConfig%5B0%5D)%EF%BC%9B%3C%2FP%3E%3CP%3ESiul2_Port_Ip_Init(NUM_OF_CONFIGURED_PINS_PortContainer_0_BOARD_InitPeripherals%2C%20g_pin_mux_InitConfigArr_PortContainer_0_BOARD_InitPeripherals)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDma_Ip_Init(%26amp%3BDma_Ip_Sa_xDmaInitPB)%EF%BC%9B%3C%2FP%3E%3CP%3ERm_Init(%26amp%3BRm_Config)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%202.%20%E5%AE%89%E8%A3%85%E5%B9%B6%E5%90%AF%E7%94%A8%20DMA%20%E4%B8%AD%E6%96%AD%E5%92%8C%20FlexCAN%20%E4%B8%AD%E6%96%AD%3C%2FP%3E%3CP%3E%2F%2F%20IntCtrl_Ip_InstallHandler(DMATCD0_IRQn%2C%20Dma0_Ch0_IRQHandler%2C%20NULL_PTR)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F%2F%20IntCtrl_Ip_EnableIrq(DMATCD0_IRQn)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F%2F%20IntCtrl_Ip_InstallHandler(FlexCAN0_1_IRQn%2C%20CAN0_ORED_0_31_MB_IRQHandler%2CNULL_PTR)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F%2F%20IntCtrl_Ip_EnableIrq(FlexCAN0_1_IRQn)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%203.%20%E5%90%AF%E5%8A%A8%20DMA%3C%2FP%3E%3CP%3E%2F%2FDma_Ip_Init(%26amp%3BDma_Ip_xDmaInitPB)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EDma_Ip_LogicChannelTransferListType%20asDmaCh1TransferList%5B2%5D%20%3D%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%7BDMA_IP_CH_SET_SOURCE_ADDRESS%EF%BC%8C(uint32_t)pu32CANFIFO1_RegAddress%7D%E3%80%81%3C%2FP%3E%3CP%3E%7BDMA_IP_CH_SET_DESTINATION_ADDRESS%2C%20(uint32_t)pu32FIFO_Data%7D%2F%2F%20(uint32_t)P1OS_Cpu_ConvertLocalAddress(%26amp%3Bpu32FIFO_Data%5B0%5D)%7D%7D%3C%2FP%3E%3CP%3E%7D%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EDma_Ip_SetLogicChannelTransferList(SA_DMA_LOGIC_CH_0%2C%20asDmaCh1TransferList%2C%202)%EF%BC%9B%3C%2FP%3E%3CP%3EDma_Ip_SetLogicChannelCommand(SA_DMA_LOGIC_CH_0%20%2C%20DMA_IP_CH_SET_HARDWARE_REQUEST)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%204.%20%E5%90%AF%E5%8A%A8%20FlexCAN0%3C%2FP%3E%3CP%3EFlexCAN_Ip_Init(INST_FLEXCAN_0%2C%26amp%3BFlexCAN_State0%2C%26amp%3BFlexCAN_Config0)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%205.%E9%85%8D%E7%BD%AE%20Rx%20FIFO%EF%BC%88%E4%BC%A0%E7%BB%9F%EF%BC%89%3C%2FP%3E%3CP%3EFlexCAN_Ip_SetRxMaskType_Privileged(INST_FLEXCAN_0%2CFLEXCAN_RX_MASK_INDIVIDUAL)%EF%BC%9B%3C%2FP%3E%3CP%3EFlexCAN_Ip_ConfigRxFifo_Privileged(INST_FLEXCAN_0%2CFLEXCAN_RX_FIFO_ID_FORMAT_A%20%2C%26amp%3BCAN0_FIFO_IdFilterTable%5B0%5D)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F%2F%20%E4%B8%BA%E7%AC%AC%E4%B8%80%E4%B8%AA%E8%BF%87%E6%BB%A4%E5%99%A8%E9%85%8D%E7%BD%AE%E5%8D%95%E7%8B%AC%E7%9A%84%E6%8E%A9%E7%A0%81%EF%BC%88%E6%8E%A5%E5%8F%97%E8%8C%83%E5%9B%B4%200x50-0x5F%EF%BC%89%3C%2FP%3E%3CP%3EFlexCAN_Ip_SetRxIndividualMask(INST_FLEXCAN_0%2C%200%2C%200x7F0%26lt%3B%26lt%3B%2019)%3B%20%2F%2F%20%E6%BB%A4%E6%B3%A2%E5%99%A8%E8%A1%A8%E4%B8%AD%E7%AC%AC%E4%B8%80%E4%B8%AA%20ID%20%E7%9A%84%E6%8E%A9%E7%A0%81%200x50%20%E8%87%B3%200x5F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%E5%8F%AF%E9%80%89%E7%9A%84%EF%BC%9A%E5%9F%BA%E4%BA%8E%20MB%20%E7%9A%84%E6%8E%A5%E6%94%B6%E8%AE%BE%E7%BD%AE%3C%2FP%3E%3CP%3E%2F%2F%20FlexCAN_Ip_ConfigRxMb(INST_FLEXCAN_0%2C%20RX_MB_IDX%2C%26amp%3Brx_info%2C%200x20u)%3B%20%2F%2F%20%E4%B8%BA%20MB%20%E5%8F%96%E6%B6%88%E6%B3%A8%E9%87%8A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%206.%20%E5%90%AF%E5%8A%A8%20FlexCAN%20%E6%8E%A7%E5%88%B6%E5%99%A8%3C%2FP%3E%3CP%3EFlexCAN_Ip_SetStartMode(INST_FLEXCAN_0)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%207.%E9%80%9A%E8%BF%87%20MB%20%E5%8F%91%E9%80%81%E5%88%9D%E5%A7%8B%E8%99%9A%E6%8B%9F%20TX%20%E6%8A%A5%E6%96%87%3C%2FP%3E%3CP%3EFlexCAN_Ip_Send(INST_FLEXCAN_0%2C%20TX_MB_IDX%2C%26amp%3Btx_info%2C%20TX_MSG_ID%2C%20dummyData)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20%E8%AF%BB%E5%8F%96%20Rx%20FIFO%EF%BC%88%E5%88%9D%E5%A7%8B%E8%AF%BB%E5%8F%96%EF%BC%89----%26gt%3BDMA%20%E5%B7%B2%E5%B0%86%E6%95%B0%E6%8D%AE%E4%BB%8E%20RxFIFO%20%E4%BC%A0%E8%BE%93%E5%88%B0%20rxFifoData%3C%2FP%3E%3CP%3EFlexCAN_Ip_RxFifo(INST_FLEXCAN_0%2C%26amp%3BrxFifoData)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%2F%2F%20%E8%AF%BB%E5%8F%96%20Rx%20MB%EF%BC%88%E5%88%9D%E5%A7%8B%E8%AF%BB%E5%8F%96%EF%BC%89%3C%2FP%3E%3CP%3E%2F%2F%20FlexCAN_Ip_Receive(INST_FLEXCAN_0%2C%20RX_MB_IDX%2C%26amp%3BrxData%2C%20FALSE)%3B%20%2F%2F%20%E5%8F%96%E6%B6%88%E5%AF%B9%20MB%20%E6%8E%A5%E6%94%B6%E7%9A%84%E6%B3%A8%E9%87%8A%3C%2FP%3E%3CP%3E%E5%BD%93%20(1)%20%7B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BB%A3%E7%A0%81%E5%9C%A8%E6%9C%89%E4%B8%AD%E6%96%AD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E5%9C%A8%E6%B2%A1%E6%9C%89%E4%B8%AD%E6%96%AD%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%E5%B7%A5%E4%BD%9C%3CBR%20%2F%3E%E6%BA%90%E5%9C%B0%E5%9D%80%E5%92%8C%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%E7%9A%84%E9%85%8D%E7%BD%AE%3CBR%20%2F%3E%EF%BC%8C%E8%AF%B7%E6%8F%90%E5%87%BA%E6%9B%B4%E5%A5%BD%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2204444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k344%20legacy%20fifo%20with%20DMA%20and%20without%20interrupt%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2204444%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3ERTD%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%B0%B1%E6%98%AF%E8%BF%99%E6%A0%B7%E7%BC%96%E5%86%99%E7%9A%84%E3%80%82%20FlexCAN_Ip_RxFifo%20%E9%85%8D%E7%BD%AE%20DMA%20%E9%80%9A%E9%81%93%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%8E%20RXFIFO%20%E6%89%A7%E8%A1%8C%E5%8D%95%E6%AC%A1%E8%AF%BB%E5%8F%96%E5%92%8C%E6%B8%85%E9%99%A4%E8%AF%B7%E6%B1%82%E3%80%82%E5%BA%94%E5%90%AF%E7%94%A8%20DMA%20%E4%B8%AD%E6%96%AD%EF%BC%8C%E8%B0%83%E7%94%A8%20DMA_Can_Callback0%EF%BC%88%E9%92%88%E5%AF%B9%20CAN0%20%E5%AE%9E%E4%BE%8B%EF%BC%89-%26gt%3BFlexCAN_CompleteRxMessageFifoData%EF%BC%8C%E6%A3%80%E6%9F%A5%20DMA%20%E6%98%AF%E5%90%A6%E5%87%BA%E9%94%99%EF%BC%8C%E5%AF%B9%E6%95%B0%E6%8D%AE%E7%BC%93%E5%86%B2%E5%8C%BA%E8%BF%9B%E8%A1%8C%E4%B8%80%E4%BA%9B%E4%BD%8D%E6%93%8D%E4%BD%9C%EF%BC%8C%E6%9C%80%E5%90%8E%E8%B0%83%E7%94%A8%20FlexCAN%20%E5%9B%9E%E8%B0%83%E5%B0%86%E7%BB%93%E6%9E%9C%E9%80%9A%E7%9F%A5%E7%94%A8%E6%88%B7%E3%80%82%E5%9C%A8%E6%AD%A4%E5%9B%9E%E8%B0%83%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%B0%83%E7%94%A8%20FlexCAN_Ip_RxFifo%20%E5%86%8D%E6%AC%A1%E5%90%AF%E7%94%A8%20DMA%20%E9%80%9A%E9%81%93%E3%80%82%3CBR%20%2F%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E5%B8%8C%E6%9C%9B%E6%9C%89%E4%B8%8D%E5%90%8C%E7%9A%84%E8%A1%8C%E4%B8%BA%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%BF%AE%E6%94%B9%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%EF%BC%88%E4%B8%8D%E5%BB%BA%E8%AE%AE%E8%BF%99%E6%A0%B7%E5%81%9A%EF%BC%89%EF%BC%8C%E6%88%96%E8%80%85%E8%87%AA%E5%B7%B1%E5%AE%9E%E7%8E%B0%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%2C%20Petr%3C%2FP%3E%3C%2FLINGO-BODY%3E
