S32k144 not receive in Logic analyzer
已解决
跳至解决方案
360 次查看
vinmotion
Hello engineers , im new to nxp and i dont know why every example CAN project for s32k144 when i test receive using logic analyzer it get all can error and cannot decode can id or data. hopefully you guys can test the code to check . Thanks a lot
1 解答
313 次查看
PetrS
I used below PCAN setting
BR, Petr
在原帖中查看解决方案
3 回复数
329 次查看
PetrS
I tested your code on S32K144EVB-Q100 and with PCAN tool connected I see CAN FD message periodically received. Using a debugger no error is detected on FlexCAN module.
In you case error frame is sent, I guess. You can check module MCR/ECR/ESR1 registers to see a state and error detected. If using S32K144EVB-Q100 as well on your side, be sure board is powered by 12V and SBC CAN transceiver is active.
BR, Petr
325 次查看
vinmotion
Thank you sir but im fresher from university and nxp is all new to me , can you please share or screen shot how config pcan view to receive above program .. .
314 次查看
PetrS
BR, Petr
