I am working with the S32K344 Mini-EVB and trying to connect a Segger J-Link debugger using the JTAG interface.
I am using the J9 connector for JTAG, but the debugger is not able to connect to the target.
I would like to know:
Is J9 the correct connector for JTAG on this board?
Do I need to change any jumper settings (for example, OpenSDA or JTAG/SWD selection)?
Should I use JTAG or SWD interface in the Segger configuration?
Currently, I am getting a connection failure in J-Link tools.
Any guidance or step-by-step instructions would be very helpful.
Thank you.
