S32k324 Rtc time keep up
3,113件の閲覧回数
Prasad_330
We are working the s32k324 controller RTC.
In our project we are able to put the controller into Standby and wakeup By CAN or UART
But after wakeup from the Standby mode, if we read the RTC value we are getting the default value.
Where we are expecting the current time from the RTC after wakeup from standby mode.
Kindly suggest any additional configuration has to done.
3,037件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
Are you storing this value in any variable or directly reading the register? Keep in mind that if you are storing this in a variable the RAM ECC initialization may delete the values upon each wakeup.
Also, I've messaged you privately through this community regarding an example project.
Julián
5 返答(返信)
3,090件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
Could you confirm if SIRC is selected by CLKSEL in RTCC register (value 0b01). Also please confirm if RTC is enabled by reading CNTEN in RTCC register.
You can also try reading the status register of reset source (MC_RGM.DES and MC_RGM.FES) to discard if any destructive reset is happening instead of functional.
Julián
3,067件の閲覧回数
Prasad_330
Yes SIRC is selected by CLKSEL in RTCC register (value 0b01).
Yes RTC is enabled by writing one in CNTEN in RTCC register.
Also SIRC is enabled in the stand y mode
3,038件の閲覧回数
Julián_AragónM
Hi @Prasad_330,
Julián
1,839件の閲覧回数
dujunqiu
hi, can you give me the example project?
2,920件の閲覧回数
Prasad_330
Thanks Julian,
Your inputs were very useful.
we used "Rtc_Ip_ConfigurePeriodicInterrupt" function which helped us to keep up the time
and generates the interrupt periodically during Standby mode.
%3CLINGO-SUB%20id%3D%22lingo-sub-2007062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k324%20RTC%E3%81%AE%E6%99%82%E9%96%93%E8%BF%BD%E3%81%84%E3%81%A4%E3%81%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2007062%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Es32k324%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9RTC%E3%81%AB%E5%8F%96%E3%82%8A%E7%B5%84%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%9F%E3%81%A1%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E3%80%81%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%92%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E7%8A%B6%E6%85%8B%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81CAN%E3%81%BE%E3%81%9F%E3%81%AFUART%E3%81%A7%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81RTC%E5%80%A4%E3%82%92%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8B%E3%81%A8%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E5%80%A4%E3%81%8C%E5%BE%97%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8B%E3%82%89%E3%81%AE%E3%82%A6%E3%82%A7%E3%82%A4%E3%82%AF%E3%82%A2%E3%83%83%E3%83%97%E5%BE%8C%E3%81%AERTC%E3%81%8B%E3%82%89%E3%81%AE%E7%8F%BE%E5%9C%A8%E6%99%82%E5%88%BB%E3%82%92%E6%9C%9F%E5%BE%85%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%82%3C%2FP%3E%3CP%3E%E8%BF%BD%E5%8A%A0%E3%81%AE%E6%A7%8B%E6%88%90%E3%82%92%E8%A1%8C%E3%81%86%E5%BF%85%E8%A6%81%E3%81%8C%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2013299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AS32k324%20RTC%E3%81%AE%E6%99%82%E9%96%93%E8%BF%BD%E3%81%84%E3%81%A4%E3%81%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2013299%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%82%B8%E3%83%A5%E3%83%AA%E3%82%A2%E3%83%B3%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E5%85%A5%E5%8A%9B%E3%81%AF%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%BD%B9%E3%81%AB%E7%AB%8B%E3%81%A1%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E3%80%8CRtc_Ip_ConfigurePeriodicInterrupt%E3%80%8D%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%9F%E3%81%AE%E3%81%A7%E3%80%81%E6%99%82%E9%96%93%E3%82%92%E4%BF%9D%E3%81%A4%E3%81%93%E3%81%A8%E3%81%8C%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%90%E3%82%A4%E3%83%A2%E3%83%BC%E3%83%89%E4%B8%AD%E3%81%AB%E5%AE%9A%E6%9C%9F%E7%9A%84%E3%81%AB%E5%89%B2%E3%82%8A%E8%BE%BC%E3%81%BF%E3%82%92%E7%94%9F%E6%88%90%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AS32k324%20RTC%E3%81%AE%E6%99%82%E9%96%93%E8%BF%BD%E3%81%84%E3%81%A4%E3%81%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008116%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%3C%2FSPAN%3E%E3%80%81%3CSPAN%3ESIRC%20%E3%81%AF%20CLKSEL%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%20RTCC%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%20(%E5%80%A4%200b01)%20%E3%81%A7%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%AF%E3%81%84%E3%80%81RTCC%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%ABCNTEN%E3%81%AB1%E3%81%A4%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%A7RTC%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%81%BE%E3%81%9F%E3%80%81SIRC%E3%81%AF%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89y%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2156645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20S32k324%20Rtc%20time%20keep%20up%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2156645%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%82%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92CAN%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E
