S32k314 adc reading
S32k314 adc reading
2,465 次查看
vasanth-sr
i have assinged the mux_output0 pin for ADC1. the channel number is not mentioned, which channel use to read the value.
i saw in the configuration ANAMUX_OUTPUT channel. is this correct?
Attached the screenshort.FYR.
5 回复数
2,360 次查看
vasanth-sr
Ok ,thanks
2,453 次查看
Senlent
Hi@vasanth-sr
No, for example,you can check the specific channel number like the way below.
S32K344_S32K324_S32K314_IOMUX.xlsx
the PTC27->ADC1_MA[0]
S32K3XXRM_rev5: Table 295.ADC channel mapping
2,451 次查看
vasanth-sr
Ok ,Thank you.
2,431 次查看
vasanth-sr
Hi team,
In our design, pin no 93 -ADC1_MA[0] (ADC1 -> mux_output0 -> PTC27) used to read voltage.
I configured this pin, this pin default direction is output not configurable as a input.
How can i configure and read ADC value from this ADC1_MA[0]?
2,423 次查看
Senlent
Hi@vasanth-sr
Could you please create a new question for this topic, I'm not familiar with it, thank you for your understanding
