S32k144 MCAL GPT interrupt can not enable
1,658件の閲覧回数
BarryQi
My EB configured the LPIT clock of GPT and enabled the hardware interrupt configuration, while specifying the notification function, but the software can not enter the notification function at runtime, may I ask whether the problem is my setting or the function call.
BarryQi_0-1715765817363.pngBarryQi_1-1715765830702.pngBarryQi_2-1715765848585.pngBarryQi_3-1715765930917.pngBarryQi_4-1715765947138.png
4 返答(返信)
1,633件の閲覧回数
VaneB
Hi @BarryQi
We provide a Gpt example code using PIT and FTM, could you please test it and let me know if the same behavior is present?
B.R.
VaneB
1,005件の閲覧回数
binZhang01
hi,where can i find the Gpt example code for PIT and FTM?
1,608件の閲覧回数
BarryQi
Hi VaneB:
I just check the interrupt and found below configuration:
I think the way the interrupt was declared was empty resulting in the interrupt not being declared properly, and I just use the default GNU as compiler, what method should I choose to declare an interrupt?
1,588件の閲覧回数
VaneB
Hi @BarryQi
Which RTD version are you using? Did you test the example code?
