S32k144 Lin communication node sleep mode
1,216件の閲覧回数
qiansan
If the Lin node enters the sleep mode, does it adjust some functions of the serial port to the low-power mode or turn it off? I would like to ask what functions are adjusted to reduce the power consumption if the node enters the sleep mode compared with the normal mode
1,203件の閲覧回数
PetrS
as per LIN specification goto_sleep command will not affect the power mode. It is up to the application to do this.
BR, Petr
