S32k144 CSEC error state
fan1234
Hi, team:
     from AN5401 , i know the error is reported in the “Error Bits” field when any error occurring during the CSEC command execution, and i want to confirm what's the impact with the chip?
     for example, if i update a key without increase the counter value, the error bit will be "CSEC_KEY_UPDATE_ERROR", then the key will be unavailable or what, and will it affect the use of flash modules?
Thanks in Advance
Cor
lukaszadrapa
Hi @fan1234
if you get "CSEC_KEY_UPDATE_ERROR", nothing will happen. The  original key can be still used, it's just not updated because you provided wrong data. It does not affect flash modules.
Lukas
lukaszadrapa
Hi @fan1234
Lukas
fan1234
other error bits will be the same? will any error of csec affect flash modules or original kes?
%3CLINGO-SUB%20id%3D%22lingo-sub-2008822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ES32k144%20CSEC%20error%20state%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20team%3A%3C%2FP%3E%3CP%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%3CSPAN%20class%3D%22%22%3Efrom%20AN5401%20%2C%20i%20know%20the%20error%26nbsp%3Bis%20reported%20in%20the%20%E2%80%9CError%20Bits%E2%80%9D%20field%26nbsp%3B%3C%2FSPAN%3Ewhen%20a%3CSPAN%20class%3D%22%22%3Eny%20error%20occurring%20during%20the%20CSEC%20command%20execution%2C%20and%20i%20want%20to%20confirm%20what's%20the%20impact%20with%20the%20chip%3F%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22%22%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3Bfor%20example%2C%20if%20i%20update%20a%20key%20without%20increase%20the%20counter%20value%2C%20the%20error%20bit%20will%20be%20%22CSEC_KEY_UPDATE_ERROR%22%2C%20then%20the%20key%20will%20be%20unavailable%20or%20what%2C%20and%26nbsp%3B%3C%2FSPAN%3Ewill%20it%20affect%20the%20use%20of%20flash%20modules%3F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3EThanks%20in%20Advance%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3ECor%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2009846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32k144%20CSEC%20error%20state%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2009846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eother%20error%20bits%20will%20be%20the%20same%3F%20will%20any%20error%20of%20csec%20affect%20flash%20modules%20or%20original%20kes%3F%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2009777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20S32k144%20CSEC%20error%20state%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2009777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F244278%22%20target%3D%22_blank%22%3E%40fan1234%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3Eif%20you%20get%20%3CSPAN%20class%3D%22%22%3E%22CSEC_KEY_UPDATE_ERROR%22%3C%2FSPAN%3E%2C%20nothing%20will%20happen.%20The%26nbsp%3B%20original%20key%20can%20be%20still%20used%2C%20it's%20just%20not%20updated%20because%20you%20provided%20wrong%20data.%20It%20does%20not%20affect%20flash%20modules.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
