S32k118evb heating
S32k118evb heating
Ashish4525
Dear all
I am facing issue is that S32k118evb is heating too much on mcu part and UJA1169 IC ,red led is continously on and I am unable to flash source code. Earlier it is used to heat little bit whenever I connect 12 volt supply for SPI testing and  with 5volt board never get heated, but now with both (supply voltage 12 and 5 volt board is heating too much and unable to flash ).
How can I fix and check cause of issue.
B.R
Ashish
lukaszadrapa
Hi @Ashish4525
the board is obviously somehow damaged, I don't think we can help here.
Lukas
