S32dsIDE error while flashing exe
5,391件の閲覧回数
Ashish4525
Dear all
I am trying import an exe file and debugging it,but while debug launching process I am facing (Error while launching command: D:\Compiler\32-bit\mingw32\bin --version).
I have added path of gdb exe in gdb debugger settings,still it shows  this error.
PFA attached file for better understanding.
Note: I am using openSDA for Flashing S32K118 EVB. The exe is build externally in eclipse. We were able to test and debug using IAR workbench demo version, but unable to do so using S32DS.
Best Regards
Ashish
2 返答(返信)
5,329件の閲覧回数
lukaszadrapa
Hi @Ashish4525
you can try to follow steps from this article, this should work:
https://community.nxp.com/t5/S32-Design-Studio-Knowledge-Base/HOWTO-download-separate-elf-srec-hex-f...
Lukas
5,346件の閲覧回数
Ashish4525
Dear All
I am still facing same problem and also waiting for response from your side.
Best Regards
Ashish
