S32K3xx question
S32K3xx question
ruixi
I have downloaded the file package "unified_bootloader_demo_V2.1", which includes three file packages: See the attachment. The first one is clearly a BOOTLOADER, but what are the purposes of the latter two files?And I compiled the first one. What should I do with the other two?
Thank you for your assistance.
lukaszadrapa
Hi @ruixi
App Demo is an application which will  be loaded to flash by the bootloader. User config folder then contains json configuration file for UI and binary form of the application.
Please notice that Unified Bootloader is only unofficial demo provided AS IS with no guarantees and no support. It's not production code.
Lukas
