[S32K3xx] - Program a byte in UTEST sector
11,948 次查看
atranzillo93
I'm trying to write a byte in UTEST sector in this block:
NB: API is called at init with interrupts disabled.
This is my code:
 HostFlash_Program((uint32_t )0x1B000780U, (uint8_t* )hseFwFeatureFlagEnabledValue, (uint32_t)8U);
eel_status_t HostFlash_Program( uint32_t Address, uint8_t* SourceAddress, uint32_t Length)
uint32_t ErrorFlags;
C40_Ip_StatusType C40_Ip_Status = STATUS_C40_IP_ERROR ;
const uint8_t *DataPtr8 = SourceAddress;
volatile uint32_t DataTemp32; /* Prevent compiler optimization when working with unaligned addresses */
/* Disable HV to finalize/abort the operation */
Fsld_FlashInstance->MCR &= ~FLASH_MCR_EHV_MASK;
/*Clear ERS and PGM bits */
Fsld_FlashInstance->MCR &= ~(FLASH_MCR_PGM_MASK|FLASH_MCR_ESS_MASK|FLASH_MCR_ERS_MASK);
/* Disable watchdog interrupt */
Fsld_FlashInstance->MCR &= ~FLASH_MCR_WDIE_MASK;
/* No interrupt request will be generated when the DONE flag is set */
Fsld_FlashInstance->MCR &= ~FLASH_MCR_PECIE_MASK;
/* Clear all error flags for main interface */
Fsld_FlashInstance->MCRS &= FLASH_MCRS_EER_MASK | \
FLASH_MCRS_SBC_MASK | \
FLASH_MCRS_AEE_MASK | \
FLASH_MCRS_EEE_MASK | \
FLASH_MCRS_RVE_MASK | \
FLASH_MCRS_RRE_MASK | \
FLASH_MCRS_RWE_MASK | \
FLASH_MCRS_PES_MASK | \
FLASH_MCRS_PEP_MASK;
/* Sector is in Utest */
Fsld_PFlashInstance->PFCBLKU_SPELOCK[0u] &= FSLD_MASK_UNLOCK_UTEST_SECTOR;
/* Write the address to be programmed */
Fsld_PFlashInstance->PFCPGM_PEADR_L = Address;
DataTemp32 = (uint32_t)DataPtr8[0U] << 0U;
DataTemp32 |= (uint32_t)DataPtr8[1U] << 8U;
DataTemp32 |= (uint32_t)DataPtr8[2U] << 16U;
DataTemp32 |= (uint32_t)DataPtr8[3U] << 24U;
Fsld_FlashInstance->DATA[0U] = DataTemp32;
DataTemp32 = (uint32_t)DataPtr8[4U] << 0U;
DataTemp32 |= (uint32_t)DataPtr8[5U] << 8U;
DataTemp32 |= (uint32_t)DataPtr8[6U] << 16U;
DataTemp32 |= (uint32_t)DataPtr8[7U] << 24U;
Fsld_FlashInstance->DATA[1U] = DataTemp32;
/* Setup program operation */
Fsld_FlashInstance->MCR |= FLASH_MCR_PGM_MASK;
/* Start internal erase/program sequence */
Fsld_FlashInstance->MCR |= FLASH_MCR_EHV_MASK;
while (0U == ((Fsld_FlashInstance->MCRS & FLASH_MCRS_DONE_MASK) >> FLASH_MCRS_DONE_SHIFT))
ErrorFlags = Fsld_FlashInstance->MCRS & (FLASH_MCRS_PEG_MASK | FLASH_MCRS_PEP_MASK | FLASH_MCRS_PES_MASK);
/* Program/Erase Good: only PEG = 1; both PEP and PES should be 0 */
if (FLASH_MCRS_PEG_MASK == ErrorFlags)
C40_Ip_Status = STATUS_C40_IP_SUCCESS;
else
C40_Ip_Status = STATUS_C40_IP_ERROR;
/* terminate program operation */
/* Terminate program operation */
Fsld_FlashInstance->MCR &= ~FLASH_MCR_PGM_MASK;
/* The write job has finished or the end of the sector was reached. Time to lock the sector */
Fsld_PFlashInstance->PFCBLKU_SPELOCK[0u] |= FSLD_MASK_LOCK_UTEST_SECTOR;
if( STATUS_C40_IP_SUCCESS == C40_Ip_Status )
return EEL_OK ;
else
return EEL_ERR_PARAMETER ;
  • #case1
If I don't place the function in RAM, it writes the byte but, just after the write uC generates a hard fault
#case 2
If I place the function in RAM, no hard fault occurs, but write operation fails. Byte is not written in UTEST sector.
Can you help me?
Thanks a lot.
标记 (1)
11,346 次查看
atranzillo93
SOLUTION:
I have separated the setting of PGM and EHV bits in two differents API.
14 回复数
11,347 次查看
atranzillo93
SOLUTION:
11,920 次查看
VaneB
Hi @atranzillo93
The UTEST Sector is an OTP (One Time Programmable). This causes the erase operations not to be allowed. You only going to be able to append new data or configuration and read data.
Writing the desired data in the UTEST Sector is the same process used to program data in other blocks.
Please check the following post. Is from other topics but explains how to write data in a UTEST sector.
[S32K3] Restrict the debug access with a password when HSE is not used
B.R.
VaneB
3,837 次查看
Haritha466
can we write data into Utest memory using the "C40_Ip_MainInterfaceWrite" API?? I have created the API using the andC40_Ip_MainInterfaceWrite write the Data at "0x1B001BF8 but getting the hardfault error.FLS_STATUS FLS_WriteMemoryRange(uint32_t SectorID, uint32_t WriteAddress, \
uint8_t *WriteData, uint32_t WriteSize)
FLS_STATUS RetSts = FLS_STATUS_ERROR;
C40_Ip_StatusType SectorStatus = C40_IP_STATUS_SECTOR_PROTECTED;
C40_Ip_StatusType ReturnCode = C40_IP_STATUS_SUCCESS;
/* Unlock the sector if locked */
SectorStatus = C40_Ip_GetLock(SectorID);
if (C40_IP_STATUS_SECTOR_PROTECTED == SectorStatus) {
/* Unlock the sector */
ReturnCode = C40_Ip_ClearLock(SectorID, GET_CPU_CORE_ID);
} else {
/* Proceed with the write if the sector is unlocked */
if (C40_IP_STATUS_SUCCESS == ReturnCode) {
/* Write data to the given address */
ReturnCode = C40_Ip_MainInterfaceWrite(WriteAddress, WriteSize, WriteData, GET_CPU_CORE_ID);
/* Wait until write completes */
while (C40_IP_STATUS_BUSY == (ReturnCode= C40_Ip_MainInterfaceWriteStatus()));
if (C40_IP_STATUS_SUCCESS != ReturnCode) {
PASLOG(ZONE_ERR, __func__, "Sector ID: %d, Address: 0x%X, Size: %d, Write status: %d", \
SectorID, WriteAddress, WriteSize, ReturnCode);
} else {
RetSts = FLS_STATUS_OK;
/* Lock the sector if it was previously locked */
/* Lock the sector */
ReturnCode = C40_Ip_SetLock(SectorID, GET_CPU_CORE_ID);
} else {
PASLOG(ZONE_ERR, __func__, "Sector ID: %d, Set lock request status: %d", SectorID, ReturnCode);
} else {
PASLOG(ZONE_ERR, __func__, "Sector ID: %d, Address: 0x%X, Size: %d, Write request status: %d", \
} else {
PASLOG(ZONE_ERR, __func__, "Sector ID: %d, Clear lock request status: %d", SectorID, ReturnCode);
return (RetSts);
11,908 次查看
atranzillo93
Hi vanessa,
I have tried your same code, the write in UTEST is correctly performed but just after the write uC goes in hard fault:
eel_status_t HostFlash1_Program(void)
C40_Ip_StatusType flashStatus;
uint32_t DcfRecord[2] = {0x00000100, 0x00100004};
/* If the target address is un-programmed state, start the programming process. */
if( (*(uint32_t *)0x1B000770 == 0xFFFFFFFF) && (*(uint32_t *)(0x1B000770+4) == 0xFFFFFFFF) )
/* Must unlock the UTEST Flash area before programming. */
Fsld_PFlashInstance->PFCBLKU_SPELOCK[0u] &= 0xFFFFFFF0U;
/* Write the new DCF records into UTEST Flash. */
flashStatus = C40_Ip_MainInterfaceWrite(0x1B000770, 8, (uint8_t *)(&DcfRecord[0]));
/* Cache_Ip_CleanByAddr(CACHE_IP_DATA, TRUE, TargetAddress, 8); */
/* Poll the Flash status until the programming sequence is done. */
do {
flashStatus = C40_Ip_MainInterfaceWriteStatus();
}while(STATUS_C40_IP_SUCCESS != flashStatus);
/* Must lock the UTEST Flash area after programming. */
Fsld_PFlashInstance->PFCBLKU_SPELOCK[0u] |= 0x0000000FU;
if( STATUS_C40_IP_SUCCESS == flashStatus )
return EEL_OK ;
else
Can you explain me why?
Best regarsds, Anna
11,901 次查看
VaneB
Hi @atranzillo93
Does the MCU go to Hard Fault when you lock the UTEST sector? Or does this happen when the MCU terminates the ostFlash1_Program(void)?
11,838 次查看
atranzillo93
Hi vanessa,
the MCU goes in hard fault when calls the API:
Anna
11,825 次查看
VaneB
Hi @atranzillo93
As mentioned, the UTEST Sector is an OTP (One Time Programmable). So, if you already write data in an address, you cannot append new data or configuration.
If the first time the data was written successfully, if you run the code, it causes a hard fault because that address is no longer accessible for writing.
11,820 次查看
atranzillo93
Hi Vanessa
address where I try to write is empty, so I CAN write.
The data are effectively written but during the read of Write status (DONE bit) an hard fault occurs.
I hope to be clear now.
See the images that I have attached to issue, please.
Anna
11,817 次查看
VaneB
Hi @atranzillo93
Could you please verify if this behavior also presents with the C40_Ip_Example?
11,814 次查看
atranzillo93
Ok ,I will verity it.
11,945 次查看
atranzillo93
The hard fault generates here:
标记 (1)
11,635 次查看
BhushanM
I faced same issue. controller was going to hard fault for both RAM and Flash region execution.
I tried adding 5ms delay inside "C40_Ip_MainInterfaceWrite" function. please refer from below.
if (TRUE == C40_Ip_bAsync)
/* Start flash access */
C40_Ip_FlashAccessCalloutStart();
HAL_DelayMs(5);
C40_Ip_pFlashBaseAddress->MCR |= FLASH_MCR_EHV_MASK;
HAL_DelayMs(5);
its working for me, executing from flash region.
11,412 次查看
atranzillo93
delay doens't solve the hard fault in my application.
Do you have any suggests?
Anita
4,927 次查看
Sanjana_k
#Hello@BhushanM did u get  the solution for problem ?If yes please help us with this .
%3CLINGO-SUB%20id%3D%22lingo-sub-1758514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%5Bs32K3xx%5D-%E5%9C%A8%20UTEST%20%E6%89%87%E5%8C%BA%E4%B8%AD%E5%AF%B9%E4%B8%80%E4%B8%AA%E5%AD%97%E8%8A%82%E8%BF%9B%E8%A1%8C%E7%BC%96%E7%A8%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758514%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%E8%BF%99%E4%B8%AA%E5%8C%BA%E5%9D%97%E7%9A%84UTEST%E6%89%87%E5%8C%BA%E4%B8%AD%E5%86%99%E4%B8%80%E4%B8%AA%E5%AD%97%E8%8A%82%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22atranzillo93_0-1700150357982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700150357982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700150357982.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F250267i7D69426B01BC175E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22atranzillo93_0-1700150357982.png%22%20alt%3D%22atranzillo93_0-1700150357982.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%B3%A8%E6%84%8F%3C%2FSTRONG%3E%EF%BC%9AAPI%20%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%E8%B0%83%E7%94%A8%EF%BC%8C%E5%B9%B6%E7%A6%81%E7%94%A8%E4%B8%AD%E6%96%AD%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%3CP%3EHostFlash_Program((uint32_t%20)0x1B000780U%2C%20(uint8_t*%20)hseFwFeatureFlagEnabledValue%2C%20(uint32_t)8U)%EF%BC%9B%3C%2FP%3E%3CP%3Eeel_status_t%20HostFlash_Program(%20uint32_t%20Address%2C%20uint8_t*%20SourceAddress%2C%20uint32_t%20Length)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Euint32_t%20ErrorFlags%3B%3CBR%20%2F%3EC40_Ip_StatusType%20C40_Ip_Status%20%3D%20STATUS_C40_IP_ERROR%20%EF%BC%9B%3CBR%20%2F%3Econst%20uint8_t%20*DataPtr8%20%3D%20SourceAddress%3B%3CBR%20%2F%3Evolatile%20uint32_t%20DataTemp32%3B%20%2F*%20%E9%98%B2%E6%AD%A2%E7%BC%96%E8%AF%91%E5%99%A8%E5%9C%A8%E5%A4%84%E7%90%86%E6%9C%AA%E5%AF%B9%E9%BD%90%E5%9C%B0%E5%9D%80%E6%97%B6%E8%BF%9B%E8%A1%8C%E4%BC%98%E5%8C%96%20*%2F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F*%20%E7%A6%81%E7%94%A8%20HV%20%E4%BB%A5%E6%9C%80%E7%BB%88%E5%AE%8C%E6%88%90%2F%E4%B8%AD%E6%AD%A2%E6%93%8D%E4%BD%9C%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~FLASH_MCR_EHV_MASK%EF%BC%9B%3CBR%20%2F%3E%2F*%20%E6%B8%85%E9%99%A4%20ERS%20%E5%92%8C%20PGM%20%E4%BD%8D%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~(FLASH_MCR_PGM_MASK%7CFLASH_MCR_ESS_MASK%7CFLASH_MCR_ERS_MASK)%3B%3CBR%20%2F%3E%2F*%20%E7%A6%81%E7%94%A8%E7%9C%8B%E9%97%A8%E7%8B%97%E4%B8%AD%E6%96%AD%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~FLASH_MCR_WDIE_MASK%EF%BC%9B%3CBR%20%2F%3E*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~FLASH_MCR_PECIE_MASK%EF%BC%9B%3CBR%20%2F%3E%2F*%20%E6%B8%85%E9%99%A4%E4%B8%BB%E6%8E%A5%E5%8F%A3%E7%9A%84%E6%89%80%E6%9C%89%E9%94%99%E8%AF%AF%E6%A0%87%E5%BF%97%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3Bmcrs%26amp%3B%3D%20flash_mcrs_eer_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_sbc_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_aee_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_eee_mask%20%7C%20%5C%20flash_mcrs_sbc_mask%20%7C%20%5C%20flash_mcrs_aee_mask%20%7C%20%5C%20flash_mcrs_eee_mask%5C%3CBR%20%2F%3Eflash_mcrs_rve_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_rre_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_rwe_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_pes_mask%20%7C%20%5C%3CBR%20%2F%3Eflash_mcrs_pep_mask%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F*%20%E6%89%87%E5%8C%BA%E5%A4%84%E4%BA%8E%20Utest%20*%2F%3CBR%20%2F%3EFsld_PFlashInstance-%26gt%3BPFCBLKU_SPELOCK%5B0u%5D%26amp%3B%3D%20FSLD_MASK_UNLOCK_UTEST_SECTOR%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%86%99%E5%85%A5%E8%A6%81%E7%BC%96%E7%A8%8B%E7%9A%84%E5%9C%B0%E5%9D%80%20*%2F%3CBR%20%2F%3EFsld_PFlashInstance-%26gt%3BPFCPGM_PEADR_L%20%3D%20%E5%9C%B0%E5%9D%80%EF%BC%9B%3C%2FP%3E%3CP%3EDataTemp32%20%3D%20(uint32_t)DataPtr8%5B0U%5D%26lt%3B%26lt%3B%200U%3B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B1U%5D%26lt%3B%26lt%3B%208U%3B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B2U%5D%26lt%3B%26lt%3B%2016U%EF%BC%9B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B3U%5D%26lt%3B%26lt%3B%2024U%3B%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BDATA%5B0U%5D%20%3D%20DataTemp32%EF%BC%9B%3C%2FP%3E%3CP%3EDataTemp32%20%3D%20(uint32_t)DataPtr8%5B4U%5D%26lt%3B%26lt%3B%200U%3B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B5U%5D%26lt%3B%26lt%3B%208U%3B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B6U%5D%26lt%3B%26lt%3B%2016U%EF%BC%9B%3CBR%20%2F%3EDataTemp32%20%7C%3D%20(uint32_t)DataPtr8%5B7U%5D%26lt%3B%26lt%3B%2024U%3B%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BDATA%5B1U%5D%20%3D%20DataTemp32%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E8%AE%BE%E7%BD%AE%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%20%7C%3D%20FLASH_MCR_PGM_MASK%EF%BC%9B%3CBR%20%2F%3E%2F*%20%E5%90%AF%E5%8A%A8%E5%86%85%E9%83%A8%E6%93%A6%E9%99%A4%2F%E7%BC%96%E7%A8%8B%E5%BA%8F%E5%88%97%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%20%7C%3D%20FLASH_MCR_EHV_MASK%EF%BC%9B%3C%2FP%3E%3CP%3Ewhile%20(0U%20%3D%3D%20((Fsld_FlashInstance-%26gt%3BMCRS%26amp%3B%20FLASH_MCRS_DONE_MASK)%26gt%3B%26gt%3B%20FLASH_MCRS_DONE_SHIFT))%3CBR%20%2F%3E%7B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3EErrorFlags%20%3D%20Fsld_FlashInstance-%26gt%3BMCRS%26amp%3B%20(FLASH_MCRS_PEG_MASK%20%7C%20FLASH_MCRS_PEP_MASK%20%7C%20FLASH_MCRS_PES_MASK)%3B%3CBR%20%2F%3E%2F*%20Program%2FErase%20Good%EF%BC%9A%E5%8F%AA%E6%9C%89%20PEG%20%3D%201%EF%BC%9BPEP%20%E5%92%8C%20PES%20%E9%83%BD%E5%BA%94%E4%B8%BA%200%20*%2F%3CBR%20%2F%3Eif%20(FLASH_MCRS_PEG_MASK%20%3D%3D%20ErrorFlags)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EC40_Ip_Status%20%3D%20STATUS_C40_IP_SUCCESS%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%3CBR%20%2F%3E%7B%3CBR%20%2F%3EC40_Ip_Status%20%3D%20STATUS_C40_IP_ERROR%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%2F*%20%E7%BB%88%E6%AD%A2%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~FLASH_MCR_EHV_MASK%3B%3CBR%20%2F%3E%2F*%20%E7%BB%88%E6%AD%A2%E7%A8%8B%E5%BA%8F%E8%BF%90%E8%A1%8C%20*%2F%3CBR%20%2F%3EFsld_FlashInstance-%26gt%3BMCR%26amp%3B%3D%20~FLASH_MCR_PGM_MASK%EF%BC%9B%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%2F*%20%E5%86%99%E5%85%A5%E4%BB%BB%E5%8A%A1%E5%B7%B2%E5%AE%8C%E6%88%90%E6%88%96%E5%B7%B2%E5%88%B0%E8%BE%BE%E6%89%87%E5%8C%BA%E7%9A%84%E6%9C%AB%E7%AB%AF%E3%80%82%E9%94%81%E5%AE%9A%E6%89%87%E5%8C%BA%E7%9A%84%E6%97%B6%E9%97%B4%20*%2F%3CBR%20%2F%3EFsld_PFlashInstance-%26gt%3BPFCBLKU_SPELOCK%5B0u%5D%20%7C%3D%20FSLD_MASK_LOCK_UTEST_SECTOR%EF%BC%9B%3C%2FP%3E%3CP%3Eif(%20STATUS_C40_IP_SUCCESS%20%3D%3D%20C40_Ip_Status%20)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20EEL_OK%20%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20EEL_ERR_PARAMETER%20%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%23%E6%A1%88%E4%BE%8B%201%3C%2FSTRONG%3E%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E4%B8%8D%E5%B0%86%E8%AF%A5%E5%87%BD%E6%95%B0%E6%94%BE%E5%9C%A8%20RAM%20%E4%B8%AD%EF%BC%8C%E5%AE%83%E4%BC%9A%E5%86%99%E5%85%A5%E5%AD%97%E8%8A%82%EF%BC%8C%E4%BD%86%E6%98%AF%EF%BC%8C%E5%B0%B1%E5%9C%A8%E5%86%99%E5%85%A5%E4%B9%8B%E5%90%8E%20uC%20%E4%BC%9A%E7%94%9F%E6%88%90%3CSTRONG%3E%E7%A1%AC%E6%95%85%E9%9A%9C%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22atranzillo93_1-1700150470064.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_1-1700150470064.png%22%20style%3D%22width%3A%20214px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_1-1700150470064.png%22%20style%3D%22width%3A%20214px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F250268iF383B650A1D0AD57%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22atranzillo93_1-1700150470064.png%22%20alt%3D%22atranzillo93_1-1700150470064.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%23%E6%A1%88%E4%BE%8B%202%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%E5%A6%82%E6%9E%9C%E6%88%91%E5%B0%86%E5%87%BD%E6%95%B0%E6%94%BE%E5%9C%A8%20RAM%20%E4%B8%AD%EF%BC%8C%E4%B8%8D%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E4%BD%86%3CSTRONG%3E%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%BC%9A%E5%A4%B1%E8%B4%A5%E3%80%82%20%3C%2FSTRONG%3E%E5%AD%97%E8%8A%82%E4%B8%8D%E6%98%AF%E5%9C%A8%20UTEST%20%E6%89%87%E5%8C%BA%E4%B8%AD%E5%86%99%E5%85%A5%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22atranzillo93_2-1700150752156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_2-1700150752156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_2-1700150752156.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F250269iD89405B8A1F48111%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22atranzillo93_2-1700150752156.png%22%20alt%3D%22atranzillo93_2-1700150752156.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2250816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2250816%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F226337%22%20target%3D%22_blank%22%3E%23Hello%40BhushanM%3C%2FA%3E%E4%BD%A0%E6%89%BE%E5%88%B0%E9%97%AE%E9%A2%98%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1787341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1787341%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%86%20PGM%20%E5%92%8C%20EHV%20%E4%BD%8D%E7%9A%84%E8%AE%BE%E7%BD%AE%E5%88%86%E4%B8%BA%E4%B8%A4%E4%B8%AA%E4%B8%8D%E5%90%8C%E7%9A%84%20API%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1785210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1785210%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E5%BB%B6%E8%BF%9F%E5%B9%B6%E4%B8%8D%E8%83%BD%E8%A7%A3%E5%86%B3%E6%88%91%E7%9A%84%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%B8%AD%E7%9A%84%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%A0%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E9%98%BF%E5%A6%AE%E5%A1%94%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1771524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1771524%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%B9%9F%E9%81%87%E5%88%B0%E4%BA%86%E5%90%8C%E6%A0%B7%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E6%8E%A7%E5%88%B6%E5%99%A8%E5%9C%A8%E6%89%A7%E8%A1%8C%20RAM%20%E5%92%8C%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%E6%97%B6%E9%83%BD%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E5%9C%A8%22C40_Ip_MainInterfaceWrite%22%20%E5%87%BD%E6%95%B0%E4%B8%AD%E6%B7%BB%E5%8A%A0%205ms%20%E5%BB%B6%E8%BF%9F%E3%80%82%E8%AF%B7%E5%8F%82%E8%A7%81%E4%B8%8B%E6%96%87%E3%80%82%3C%2FP%3E%3CP%3Eif%20(TRUE%20%3D%3D%20C40_Ip_bAsync)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%20%E5%90%AF%E5%8A%A8%E9%97%AA%E5%AD%98%E8%AE%BF%E9%97%AE%20*%2F%3CBR%20%2F%3EC40_Ip_FlashAccessCalloutStart()%3B%3CBR%20%2F%3EHAL_DelayMs(5)%EF%BC%9B%3CBR%20%2F%3E%2F*%20%E5%90%AF%E5%8A%A8%E5%86%85%E9%83%A8%E6%93%A6%E9%99%A4%2F%E7%BC%96%E7%A8%8B%E5%BA%8F%E5%88%97%20*%2F%3CBR%20%2F%3EC40_Ip_pFlashBaseAddress-%26gt%3BMCR%20%7C%3D%20FLASH_MCR_EHV_MASK%EF%BC%9B%3CBR%20%2F%3EHAL_DelayMs(5)%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%E5%AE%83%E5%AF%B9%E6%88%91%E6%9C%89%E6%95%88%EF%BC%8C%E4%BB%8E%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%E6%89%A7%E8%A1%8C%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1760923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1760923%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A5%BD%E7%9A%84%EF%BC%8C%E6%88%91%E4%BC%9A%E6%A0%B8%E5%AE%9E%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1760922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1760922%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206920%22%20target%3D%22_blank%22%3E%40atranzillo93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%83%BD%E5%90%A6%E9%AA%8C%E8%AF%81%E4%B8%80%E4%B8%8B%20C40_Ip_Example%20%E6%98%AF%E5%90%A6%E4%B9%9F%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E8%A1%8C%E4%B8%BA%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1760907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1760907%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E7%93%A6%E5%86%85%E8%90%A8%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E5%86%99%E7%9A%84%E5%9C%B0%E5%9D%80%E6%98%AF%E7%A9%BA%E7%9A%84%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E5%8F%AF%E4%BB%A5%E5%86%99%E3%80%82%3C%2FP%3E%3CP%3E%E6%95%B0%E6%8D%AE%E5%B7%B2%E6%9C%89%E6%95%88%E5%86%99%E5%85%A5%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%AF%BB%E5%8F%96%E5%86%99%E5%85%A5%E7%8A%B6%E6%80%81%EF%BC%88DONE%20%E4%BD%8D%EF%BC%89%E6%97%B6%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%B8%8C%E6%9C%9B%E7%8E%B0%E5%9C%A8%E8%83%BD%E8%AF%B4%E6%B8%85%E6%A5%9A%E3%80%82%3C%2FP%3E%3CP%3E%E8%AF%B7%E7%9C%8B%E6%88%91%E9%99%84%E5%9C%A8%E9%97%AE%E9%A2%98%E5%90%8E%E9%9D%A2%E7%9A%84%E5%9B%BE%E7%89%87%E3%80%82%3C%2FP%3E%3CP%3E%E5%AE%89%E5%A8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1760904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1760904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206920%22%20target%3D%22_blank%22%3E%40atranzillo93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E5%89%8D%E6%89%80%E8%BF%B0%EF%BC%8CUTEST%E6%89%87%E5%8C%BA%E6%98%AF%E4%B8%80%E4%B8%AAOTP%EF%BC%88%E4%B8%80%E6%AC%A1%E6%80%A7%E5%8F%AF%E7%BC%96%E7%A8%8B%EF%BC%89%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%A6%82%E6%9E%9C%E5%B7%B2%E7%BB%8F%E5%9C%A8%E5%9C%B0%E5%9D%80%E4%B8%AD%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%B0%B1%E4%B8%8D%E8%83%BD%3CSPAN%3E%E5%86%8D%E6%B7%BB%E5%8A%A0%E6%96%B0%E6%95%B0%E6%8D%AE%E6%88%96%E9%85%8D%E7%BD%AE%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E7%AC%AC%E4%B8%80%E6%AC%A1%E6%88%90%E5%8A%9F%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%EF%BC%8C%E5%A6%82%E6%9E%9C%E8%BF%90%E8%A1%8C%E4%BB%A3%E7%A0%81%EF%BC%8C%E5%B0%B1%E4%BC%9A%E5%AF%BC%E8%87%B4%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%AF%A5%E5%9C%B0%E5%9D%80%E5%B7%B2%E6%97%A0%E6%B3%95%E5%86%99%E5%85%A5%E3%80%82%20%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1760714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1760714%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%87%A1%E5%A6%AE%E8%8E%8E%E3%80%81%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%BD%93%E8%B0%83%E7%94%A8%20API%20%E6%97%B6%EF%BC%8CMCU%20%E4%BC%9A%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%9A%3C%2FP%3E%3CP%3EflashStatus%20%3D%3CSTRONG%3EC40_Ip_MainInterfaceWriteStatus()%EF%BC%9B%3C%2FSTRONG%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E5%AE%89%E5%A8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1759157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1759157%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206920%22%20target%3D%22_blank%22%3E%40atranzillo93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E9%94%81%E5%AE%9A%20UTEST%20%E6%89%87%E5%8C%BA%E6%97%B6%EF%BC%8CMCU%20%E6%98%AF%E5%90%A6%E4%BC%9A%E8%BF%9B%E5%85%A5%E7%A1%AC%E6%95%85%E9%9A%9C%E7%8A%B6%E6%80%81%EF%BC%9F%E8%BF%98%E6%98%AF%E5%BD%93%20MCU%20%E7%BB%88%E6%AD%A2%20ostFlash1_Program(void)%20%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1758993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758993%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%87%A1%E5%A6%AE%E8%8E%8E%E3%80%81%3C%2FP%3E%3CP%3E%E6%88%91%E5%B0%9D%E8%AF%95%E4%BA%86%E4%B8%8E%E6%82%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8CUTEST%20%E4%B8%AD%E7%9A%84%E5%86%99%E5%85%A5%E6%AD%A3%E7%A1%AE%E6%89%A7%E8%A1%8C%EF%BC%8C%E4%BD%86%E5%86%99%E5%85%A5%E5%90%8E%3CSTRONG%3EUC%20%E5%87%BA%E7%8E%B0%E7%A1%AC%E6%95%85%E9%9A%9C%3C%2FSTRONG%3E%EF%BC%9A%3C%2FP%3E%3CP%3Eeel_status_t%3CSTRONG%3EHostFlash1_Program%3C%2FSTRONG%3E(void)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EC40_Ip_StatusType%20flashStatus%3B%3CBR%20%2F%3Euint32_t%20DcfRecord%5B2%5D%20%3D%20%7B0x00000100%2C%200x00100004%7D%3B%3CBR%20%2F%3E%2F*%20%E5%A6%82%E6%9E%9C%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%E5%A4%84%E4%BA%8E%E6%9C%AA%E7%BC%96%E7%A8%8B%E7%8A%B6%E6%80%81%EF%BC%8C%E5%88%99%E5%BC%80%E5%A7%8B%E7%BC%96%E7%A8%8B%E8%BF%87%E7%A8%8B%E3%80%82*%2F%3CBR%20%2F%3Eif(%20(*(uint32_t%20*)0x1B000770%20%3D%3D%200xFFFFFFFF)%26amp%3B%26amp%3B%20(*(uint32_t%20*)(0x1B000770%2B4)%20%3D%3D%200xFFFFFFFF)%20)%3CBR%20%2F%3E%7B%3CBR%20%2F%3E%2F*%20%E7%BC%96%E7%A8%8B%E5%89%8D%E5%BF%85%E9%A1%BB%E8%A7%A3%E9%94%81UTEST%20%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%E3%80%82*%2F%3CBR%20%2F%3EFsld_PFlashInstance-%26gt%3BPFCBLKU_SPELOCK%5B0u%5D%26amp%3B%3D%200xFFFFFF0U%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E5%B0%86%E6%96%B0%E7%9A%84%20DCF%20%E8%AE%B0%E5%BD%95%E5%86%99%E5%85%A5%20UTEST%20Flash%E3%80%82*%2F%3CBR%20%2F%3EflashStatus%20%3D%20C40_Ip_MainInterfaceWrite(0x1B000770%2C%208%2C%20(uint8_t%20*)(%26amp%3BDcfRecord%5B0%5D))%3B%3CBR%20%2F%3E%2F*%20Cache_Ip_CleanByAddr(CACHE_IP_DATA%2C%20TRUE%2C%20TargetAddress%2C%208)%3B%20*%2F%3C%2FP%3E%3CP%3E%2F*%20%E8%BD%AE%E8%AF%A2%E9%97%AA%E5%AD%98%E7%8A%B6%E6%80%81%EF%BC%8C%E7%9B%B4%E5%88%B0%E7%BC%96%E7%A8%8B%E5%BA%8F%E5%88%97%E5%AE%8C%E6%88%90%E3%80%82*%2F%3CBR%20%2F%3Edo%20%7B%3CBR%20%2F%3EflashStatus%20%3D%20C40_Ip_MainInterfaceWriteStatus()%3B%3CBR%20%2F%3E%7Dwhile(STATUS_C40_IP_SUCCESS%20!%3D%20flashStatus)%EF%BC%9B%3C%2FP%3E%3CP%3E%2F*%20%E7%BC%96%E7%A8%8B%E5%90%8E%E5%BF%85%E9%A1%BB%E9%94%81%E5%AE%9AUTEST%20%E9%97%AA%E5%AD%98%E5%8C%BA%E5%9F%9F%E3%80%82*%2F%3CBR%20%2F%3EFsld_PFlashInstance-%26gt%3BPFCBLKU_SPELOCK%5B0u%5D%20%7C%3D%200x0000000FU%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3Eif(%20STATUS_C40_IP_SUCCESS%20%3D%3D%20flashStatus%20)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20EEL_OK%20%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3Eelse%3CBR%20%2F%3E%7B%3CBR%20%2F%3Ereturn%20EEL_ERR_PARAMETER%20%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22atranzillo93_0-1700215264747.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700215264747.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700215264747.png%22%20style%3D%22width%3A%20359px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F250412i93F0E12B246608FE%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22atranzillo93_0-1700215264747.png%22%20alt%3D%22atranzillo93_0-1700215264747.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%A0%E8%83%BD%E8%A7%A3%E9%87%8A%E4%B8%80%E4%B8%8B%E5%8E%9F%E5%9B%A0%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%EF%BC%8C%E5%AE%89%E5%A8%9C%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1758643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758643%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F206920%22%20target%3D%22_blank%22%3E%40atranzillo93%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EUTEST%20%E9%83%A8%E4%BB%B6%E6%98%AF%E4%B8%80%E6%AC%A1%E6%80%A7%E5%8F%AF%E7%BC%96%E7%A8%8B%EF%BC%88OTP%EF%BC%89%E5%99%A8%E4%BB%B6%E3%80%82%E8%BF%99%E5%AF%BC%E8%87%B4%E6%93%A6%E9%99%A4%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%A2%AB%E5%85%81%E8%AE%B8%E3%80%82%E6%82%A8%E5%8F%AA%E8%83%BD%E8%BF%BD%E5%8A%A0%E6%96%B0%E7%9A%84%E6%95%B0%E6%8D%AE%E6%88%96%E9%85%8D%E7%BD%AE%EF%BC%8C%E5%B9%B6%E8%AF%BB%E5%8F%96%E6%95%B0%E6%8D%AE%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9C%A8UTEST%20%E6%89%87%E5%8C%BA%E5%86%99%E5%85%A5%E6%89%80%E9%9C%80%E6%95%B0%E6%8D%AE%E7%9A%84%E8%BF%87%E7%A8%8B%E4%B8%8E%E5%9C%A8%E5%85%B6%E4%BB%96%E5%8C%BA%E5%9D%97%E7%BC%96%E7%A8%8B%E7%9B%B8%E5%90%8C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%9F%A5%E7%9C%8B%E4%B8%8B%E9%9D%A2%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%E6%9D%A5%E8%87%AA%E5%85%B6%E4%BB%96%E4%B8%BB%E9%A2%98%EF%BC%8C%E4%BD%86%E8%A7%A3%E9%87%8A%E4%BA%86%E5%A6%82%E4%BD%95%E5%9C%A8%20UTEST%20%E6%89%87%E5%8C%BA%E4%B8%AD%E5%86%99%E5%85%A5%E6%95%B0%E6%8D%AE%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FS32K-Knowledge-Base%2FS32K3-Restrict-the-debug-access-with-a-password-when-HSE-is-not%2Fta-p%2F1735073%22%20target%3D%22_blank%22%3E%5BS32K3%5D%E5%9C%A8%E6%9C%AA%E4%BD%BF%E7%94%A8%20HSE%20%E6%97%B6%EF%BC%8C%E4%BD%BF%E7%94%A8%E5%AF%86%E7%A0%81%E9%99%90%E5%88%B6%E8%B0%83%E8%AF%95%E8%AE%BF%E9%97%AE%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EB.R.%3C%2FP%3E%0A%3CP%3EVaneB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1758518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1758518%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E7%A1%AC%E6%95%85%E9%9A%9C%E5%9C%A8%E8%BF%99%E9%87%8C%E4%BA%A7%E7%94%9F%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22atranzillo93_0-1700151260382.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700151260382.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22atranzillo93_0-1700151260382.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F250271i1375EF472424A68C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22atranzillo93_0-1700151260382.png%22%20alt%3D%22atranzillo93_0-1700151260382.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2317869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20%5BS32K3xx%5D%20-%20Program%20a%20byte%20in%20UTEST%20sector%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2317869%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%82%A8%E5%A5%BD%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E4%BB%AC%E8%83%BD%E5%90%A6%E4%BD%BF%E7%94%A8%22C40_Ip_MainInterfaceWrite%22%20API%20%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%20Utest%20%E5%86%85%E5%AD%98%EF%BC%9F%E6%88%91%E5%88%9B%E5%BB%BA%E4%BA%86%20API%EF%BC%8C%E4%BD%BF%E7%94%A8%20andC40_Ip_MainInterfaceWrite%20%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%220x1B001BF8%EF%BC%8C%E4%BD%86%E5%87%BA%E7%8E%B0%E4%BA%86%E7%A1%AC%E6%95%85%E9%9A%9C%E9%94%99%E8%AF%AF%E3%80%82FLS_STATUS%20FLS_WriteMemoryRange(uint32_t%20SectorID%2C%20uint32_t%20WriteAddress%2C%20%5C%3CBR%20%2F%3Euint8_t%20*WriteData%2C%20uint32_t%20WriteSize)%3CBR%20%2F%3E%7B%3CBR%20%2F%3EFLS_STATUS%20RetSts%20%3D%20FLS_STATUS_ERROR%3B%3CBR%20%2F%3EC40_Ip_StatusType%20SectorStatus%20%3D%20C40_IP_STATUS_SECTOR_PROTECTED%EF%BC%9B%3CBR%20%2F%3EC40_Ip_StatusType%20ReturnCode%20%3D%20C40_IP_STATUS_SUCCESS%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20%E5%A6%82%E6%9E%9C%E9%94%81%E5%AE%9A%E6%89%87%E5%8C%BA%EF%BC%8C%E5%88%99%E8%A7%A3%E9%99%A4%E9%94%81%E5%AE%9A%20*%2F%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3ESectorStatus%20%3D%20C40_Ip_GetLock(SectorID)%EF%BC%9B%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SECTOR_PROTECTED%20%3D%3D%20SectorStatus)%20%7B%3CBR%20%2F%3E%2F*%20%E8%A7%A3%E9%94%81%E6%89%87%E5%8C%BA%20*%2F%3CBR%20%2F%3EReturnCode%20%3D%20C40_Ip_ClearLock(SectorID%2C%20GET_CPU_CORE_ID)%EF%BC%9B%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3EReturnCode%20%3D%20C40_IP_STATUS_SUCCESS%EF%BC%9B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20%E5%A6%82%E6%9E%9C%E6%89%87%E5%8C%BA%E5%B7%B2%E8%A7%A3%E9%94%81%EF%BC%8C%E5%88%99%E7%BB%A7%E7%BB%AD%E5%86%99%E5%85%A5%20*%2F%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SUCCESS%20%3D%3D%20ReturnCode)%20%7B%3CBR%20%2F%3E%2F*%20%E5%B0%86%E6%95%B0%E6%8D%AE%E5%86%99%E5%85%A5%E7%BB%99%E5%AE%9A%E5%9C%B0%E5%9D%80%20*%2F%3CBR%20%2F%3EReturnCode%20%3D%20C40_Ip_MainInterfaceWrite(WriteAddress%2C%20WriteSize%2C%20WriteData%2C%20GET_CPU_CORE_ID)%EF%BC%9B%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SUCCESS%20%3D%3D%20ReturnCode)%20%7B%3CBR%20%2F%3E%2F*%20%E7%AD%89%E5%BE%85%E7%9B%B4%E5%88%B0%E5%86%99%E5%85%A5%E5%AE%8C%E6%88%90%20*%2F%3CBR%20%2F%3Ewhile%20(C40_IP_STATUS_BUSY%20%3D%3D%20(ReturnCode%3D%20C40_IP_MainInterfaceWriteStatus()))%3B%3CBR%20%2F%3E%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SUCCESS%20%EF%BC%81%3D%20ReturnCode)%20%7B%3CBR%20%2F%3EPASLOG(ZONE_ERR%2C__func__%2C%22Sector%20ID%3A%25d%2C%20Address%EF%BC%9A0x%25X%2C%20Size%3A%25d%2C%20Write%20status%EF%BC%9A%25d%22%2C%20%5C%3CBR%20%2F%3ESectorID%2C%20WriteAddress%2C%20WriteSize%2C%20ReturnCode)%3B%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3ERetSts%20%3D%20FLS_STATUS_OK%EF%BC%9B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3E%2F*%20%E9%94%81%E5%AE%9A%E6%89%87%E5%8C%BA%EF%BC%88%E5%A6%82%E6%9E%9C%E4%B9%8B%E5%89%8D%E5%B7%B2%E9%94%81%E5%AE%9A%EF%BC%89%20*%2F%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SECTOR_PROTECTED%20%3D%3D%20SectorStatus)%20%7B%3CBR%20%2F%3E%2F*%20%E9%94%81%E5%AE%9A%E6%89%87%E5%8C%BA%20*%2F%3CBR%20%2F%3EReturnCode%20%3D%20C40_Ip_SetLock(SectorID%2C%20GET_CPU_CORE_ID)%EF%BC%9B%3CBR%20%2F%3Eif%20(C40_IP_STATUS_SUCCESS%20%3D%3D%20ReturnCode)%20%7B%3CBR%20%2F%3ERetSts%20%3D%20FLS_STATUS_OK%3B%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3EPASLOG(ZONE_ERR%2C__func__%2C%22Sector%20ID%EF%BC%9A%25d%2C%20%E8%AE%BE%E7%BD%AE%E9%94%81%E5%AE%9A%E8%AF%B7%E6%B1%82%E7%8A%B6%E6%80%81%EF%BC%9A%25d%22%2C%20SectorID%2C%20ReturnCode)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3EPASLOG(ZONE_ERR%2C__func__%2C%22Sector%20ID%3A%25d%2C%20Address%EF%BC%9A0x%25X%2C%20Size%3A%25d%2C%20Write%20request%20status%3A%25d%22%2C%20%5C%3CBR%20%2F%3ESectorID%2C%20WriteAddress%2C%20WriteSize%2C%20ReturnCode)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%20else%20%7B%3CBR%20%2F%3EPASLOG(ZONE_ERR%2C__func__%2C%22Sector%20ID%EF%BC%9Ad%2C%20Clear%20lock%20request%20status%3A%25d%22%2C%20SectorID%2C%20ReturnCode)%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%3CBR%20%2F%3Ereturn%20(RetSts)%3B%3CBR%20%2F%3E%7D%3C%2FLINGO-BODY%3E
