S32K3xx OTA BootLoader
3,504件の閲覧回数
Alicetian
Hello:
I learned that the S32K3xx has OTA capabilities,When the OTA feature is enabled,Supports A/B swap and OTA Roll back.
Traditional firmware updates are via BootLoader,As shown in the following figure.
If I want to use the S32K3xx OTA function,Do I still need a separate BootLoader? Or integrate BootLoader flashing into App Firmware.
If a separate BootLoader is required,How the BootLoader memory region is divided.
Looking forward to your reply,Thanks!
3 返答(返信)
3,490件の閲覧回数
VaneB
Hi @Alicetian
There is an OTA demo for S32K3 that you can find at S32K3 Reference Software -> Automotive SW - S32K3 Reference Software,
If you are not able to access it, please get in touch with your NXP representative for access.
Also, take a look at Automotive Security and Over-the-Air (OTA) solution with S32K3 MCU.
B.R.
VaneB
3,428件の閲覧回数
Alicetian
Thank you very much for your reply, Whether there is a firmware installation project, For example S32K3x4_HSE_FW_INSTALL_Demo,So I can install the AB Swap Firmware Through PE tool.
3,414件の閲覧回数
VaneB
Hi @Alicetian
You can download HSE FW and HSE demo app from S32K3 Standard Software -> S32K3 Reference Software packages.
